Check engine light goes on after about a few minutes of driving
Okay, I got a few problems that I need to take care of. I got a 98 B18B in a 99 EX. After a while of regular driving, the check engine will go on. Than when it does go on, the MPH tach will die and drop to 0. Checked for loose plugs, checked for bad grounds and checked to ECU codes. Nothing seems out of place. Anything else I should check? Possibly bad secondary O2?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceNmotioN »</TD></TR><TR><TD CLASS="quote">Okay, I got a few problems that I need to take care of. I got a 98 B18B in a 99 EX. After a while of regular driving, the check engine will go on. Than when it does go on, the MPH tach will die and drop to 0. Checked for loose plugs, checked for bad grounds and checked to ECU codes. Nothing seems out of place. Anything else I should check? Possibly bad secondary O2?</TD></TR></TABLE>
Why would a bad secondary 02 Cause you instrument cluster to die?
Not a clue man, sounds electrical, have you tried swappin comporable ecu's w/ a friend.
jlsmi2
19
Jan 15, 2016 08:37 AM
ttk3
16
Apr 23, 2007 11:21 AM
