6gen brake lights problem
Old Jun 21, 2003 | 04:11 PM
LeonZ's Avatar
Default 6gen brake lights problem
after installing the factory spoiler, all 3 brake lights worked fine in my 6gen coupe, i wired the 2 wires from the spoiler into where the third brake light connector goes and it worked for like a minute. then all of a sudden, none of the 3 brake lights worked, not even when i reconnected the third brake connector back to the original 3rd brake light, none of them work. parking lights still work, all the connectors seem to be ok, the fuse is ok, but the brakes dont work. any ideas? thanks a lot.
EDIT: never mind, i fixed it. the fuse kept blowing cuz i found a tiny little piece of bare wire.
Modified by LeonZ at 10:32 PM 6/22/2003
Old Jun 21, 2003 | 04:17 PM
iam7head's Avatar
Default Re: 6gen brake lights problem (LeonZ)
sounds like you blow the fuse, did you check all THREE fuse box?
Toe_fur
Mar 10, 2013 04:44 PM
arkroyal
Sep 21, 2010 12:05 AM
ek4_b16a
Jul 2, 2009 10:20 AM
dankies
Feb 8, 2006 08:32 PM
B00ST2nR
Jul 12, 2004 04:57 PM
