Rotors
Old Jun 21, 2003 | 03:58 PM
BigLoadChoakHard's Avatar
Default Rotors
Iam gonna be doing a front brake job on a 97 Accord 4dr 2.2 does anyone have tips or a write up on how to do the front rotors
Old Jun 21, 2003 | 06:01 PM
Hondaaccordvtec's Avatar
Default Re: Rotors (BigLoadChoakHard)
Better make sure you have access to a press as the front rotors are pressed onto the hubs.
Old Jun 21, 2003 | 06:06 PM
iam7head's Avatar
Default Re: Rotors (Hondaaccordvtec)
They are pressed=cant get it off with regular tools($$)
Old Jun 21, 2003 | 08:52 PM
Martaigne's Avatar
Default Re: Rotors (iam7head)
Am I the only person on this planet that can get the front brake rotors off without a press or slide hammer?
It's still a pain in the ***, but if you remove the knuckle, then take out the 4 bolts holding the assembled bearing/hub in, then pop the bearing out of the knuckle (may require some coaxing with a hammer, sometimes they just fall out), then remove the 4 bolts holding the rotor on, turn the rotor 45 degrees, and it pulls off right over the bearing, with room to spare.
Old Jun 21, 2003 | 09:03 PM
94AccordCoupe's Avatar
Default Re: Rotors (Martaigne)
QUOTE=Martaigne]
It's still a pain in the ***, but if you remove the knuckle, then take out the 4 bolts holding the assembled bearing/hub in, then pop the bearing out of the knuckle (may require some coaxing with a hammer, sometimes they just fall out), then remove the 4 bolts holding the rotor on, turn the rotor 45 degrees, and it pulls off right over the bearing, with room to spare.[/QUOTE]
Haven't there been 2 or 3 threads about this is the past few days?
Well IMO you should take your knuckles to a shop unless you want to take the chance of damaging your $70 bearing or if you plan on replacing them anyways. I replaced mine about a month ago and I tried to push the hub out from the back and my bearing came apart. I took it to a shop and they took the old ones off and put the new rotors on for like $30. Save yourself some agrivation
Old Jun 21, 2003 | 10:48 PM
Sinisterh22a's Avatar
i did mine with out a press just a slide hammer thats all pain in the *** more then anything but hey it works
Old Jun 22, 2003 | 06:41 AM
thanks for the replies guys i have the knuckles off i guess iam goin to the machine shop mon
2KCivicDude
Dec 1, 2019 01:03 AM
bryan0
Mar 25, 2014 10:57 PM
accord_si
Jul 31, 2006 06:20 AM
TURBO
Jul 15, 2004 12:26 PM
weekendracer
Apr 7, 2002 04:47 PM
