How to change taillights inITR ?
Old Jun 21, 2003 | 02:20 PM
chuckus's Avatar
Default How to change taillights inITR ?
Do i just remove the rear bar thats attached to the back wall of the trunk? Do i have to tighten it to a certain ft./lb.? I need to replace some burnt bulbs back there
thanks
Old Jun 21, 2003 | 02:26 PM
uNF$@#!'s Avatar
Default Re: How to change taillights inITR ? (chuckus)
according to my Heims manual, it says 220 ft lbs of torque for each one.
of course, i wouldnt trust my heims.
Old Jun 21, 2003 | 02:47 PM
yellow blur's Avatar
It is not necessary to remove that bar if you're only changing light bulbs. There should be two flaps that you can rip out which will give you access to the bulbs.
Ed
Old Jun 21, 2003 | 04:07 PM
NSX Bob's Avatar
New User
Please tell me you're not putting in Altezza's........
Old Jun 21, 2003 | 04:26 PM
g5r's Avatar
g5r
Default Re: How to change taillights inITR ? (Type R Bob)
getting to the taillights is easy. just remove the back black panal.
Old Jun 21, 2003 | 04:36 PM
Eric R's Avatar
When I installed my altezzas, I didn't have to remove no freaking bar, y0!
Old Jun 22, 2003 | 06:00 PM
chuckus's Avatar
im not installing any altezzas, some bulbs are out others are dim, i need to remove the entire back panel to get to all the lights, but there is that tie bar there.
i just wanted to know if it was safe to remove it and put it back on, and how many ft./lb.'s i needed to torque it
thats all
Old Jun 22, 2003 | 06:55 PM
RickV's Avatar
Default Re: (chuckus)
It's safe to remove it (it's their to add rigidity to the car when cornering) then all you have to do is push down the centers of the plastic rivits which will allow you to remove them and then the panel. One word of warning though - don't push the rivit centers too far as they can pop out all together and are an absolute bitch to find again.
Old Jun 22, 2003 | 08:50 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chuckus &raquo;</TD></TR><TR><TD CLASS="quote">i need to remove the entire back panel to get to all the lights, but there is that tie bar there.</TD></TR></TABLE>
Neither the "entire back panel" nor the rear tie bar need to be removed to access the tail light bulbs or to remove the actual tail lights.
Old Jun 22, 2003 | 09:27 PM
RickV's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Neither the "entire back panel" nor the rear tie bar need to be removed to access the tail light bulbs or to remove the actual tail lights. </TD></TR></TABLE>
That all depends on which globes you are replacing - the ones closest to the center of the car are close to impossible to change without removing the rear panel. Besides which, why would Honda/Acura use quick release rivits if you didn't need to remove that panel?
Old Jun 22, 2003 | 09:38 PM
Padawan's Avatar
Darth ModerVader
Default Re: (RickV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RickV &raquo;</TD></TR><TR><TD CLASS="quote">That all depends on which globes you are replacing - the ones closest to the center of the car are close to impossible to change without removing the rear panel. Besides which, why would Honda/Acura use quick release rivits if you didn't need to remove that panel?</TD></TR></TABLE>
The only quick-fasteners that need to be removed are the four along the top. The rear panel can then be folded back slightly to access either the bulbs or the nuts that hold the tail lights in. The rear tie bar and the quick-fasteners securing the bottom of the panel don't interfere with this process, and can be left intact.
maraster
May 25, 2019 10:56 AM
sleeperteg
Aug 17, 2005 08:38 AM
Mr.Speed
May 1, 2005 12:19 PM
VADE-R
Nov 9, 2002 08:40 PM
KF_S2000
Feb 1, 2002 08:51 PM
