Window/Door Panel Problem
Old Jun 21, 2003 | 01:18 PM
Vinny Chase's Avatar
Default Window/Door Panel Problem
Ok, so I was installing a 6 1/2 inch JBL speaker in my driver side door, so I took the door panel off, put in the speaker, and plugged all the harnesses back into their spots, and put the door panel on, tested the speaker, it was fine, but then went to roll up my windows, and the drivers side was fine, but the passenger side will not roll up, on either the driver or passenger switch, and yes I checked and it is not the window lock thing. Thanks in advance for any help you can give me. P.S. I havent put the passenger side speaker in yet
Old Jun 21, 2003 | 01:46 PM
Default Re: Window/Door Panel Problem (Vince10984)
also i just noticed that the locks will not lock with the switch that should lock them both, could it be wiring?
Old Jun 21, 2003 | 04:49 PM
IGGY's Avatar
Wrong forum. Try the Integra or Audio/Security forum.
Old Jun 21, 2003 | 04:52 PM
Eric R's Avatar
Anyway, did you checked if the plugs were well connected all the way in?
Old Jun 21, 2003 | 09:20 PM
Default Re: Window/Door Panel Problem (Tweety R)
yea, and I already tried the integra forum, no responses
Old Jun 22, 2003 | 08:52 AM
GeorgeY's Avatar
did you check your fuse.
Old Jun 22, 2003 | 08:53 AM
JDM CTR '00's Avatar
Default Re: Window/Door Panel Problem (GeorgeY)
maybe something is cought behind the door panel try to remove it and reinstall it.
Old Jun 22, 2003 | 11:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeorgeY &raquo;</TD></TR><TR><TD CLASS="quote">did you check your fuse.</TD></TR></TABLE>
DAMNIT something that dumb and I overlooked it, thanks for your help everyone, its fixed
:jdmshmaydm:
Aug 31, 2010 07:34 AM
street_devils
Jul 21, 2008 05:31 PM
Vinny Chase
Audio / Security / Video
Jun 22, 2003 05:06 PM
Vinny Chase
Jun 21, 2003 08:37 AM
