Anyone running an t3/t4e w/SFP manifold?
Old Jun 21, 2003 | 01:01 PM
IloveNewt's Avatar
Default Anyone running an t3/t4e w/SFP manifold?
If so what kinda mods did u need? I knwo you would need some sort of spacer either between the manifold/head or manifolf/turbo to get the compressor housing to fit. What did u end up doign and how much of a spacer did you use?
Old Jun 21, 2003 | 02:56 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Anyone running an t3/t4e w/SFP manifold? (MordecaiPSI)
i am considering just buying an SFP mani so i can have at least something to roll with until i get my custom setup done, i think the only problems with the SFP mani are if you have the T04S compressor, since the compressor is larger, it has clearance issues with the block
Old Jun 21, 2003 | 08:22 PM
IloveNewt's Avatar
Default Re: Anyone running an t3/t4e w/SFP manifold? (Boosted97Lude)
Yea exactly. I think anything tahst bigger than a t04b is gonan have probs hittin the block. Ive heard of peopel puttin spacers to give it some room but i wanna know where the put it and how big of a spacer it was.
Old Jun 21, 2003 | 11:06 PM
Firedrake's Avatar
I have an SFP and a T04e, you'll need to hack the **** out of the stock motor mount bracket and notch into the block where the top-right motor mount bolt goes, and you'll only be able to run 2 bolts in it. Don't put in spacers, just cut the block and the mount (it's not that bad)......
Brian
Old Jun 22, 2003 | 02:01 AM
safe driver's Avatar
Default Re: Anyone running an t3/t4e w/SFP manifold? (Firedrake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Firedrake &raquo;</TD></TR><TR><TD CLASS="quote">I have an SFP and a T04e, you'll need to hack the **** out of the stock motor mount bracket and notch into the block where the top-right motor mount bolt goes, and you'll only be able to run 2 bolts in it. Don't put in spacers, just cut the block and the mount (it's not that bad)......
Brian</TD></TR></TABLE>
yep I had to do the same thing.
Old Jun 22, 2003 | 12:33 PM
IloveNewt's Avatar
I had to cut the mount for the B housing. I dont really want to cut the block if i dont HAVE to. Did u try to use spacers?
Old Jun 22, 2003 | 02:22 PM
it depends on which turbo you're using. if you use a 5 bolt turbo, you will not have to shave the block.. only the motor-mount. but with the newer 4 bolt design you will have the shave the block.
Zeusfire69
Sep 18, 2013 06:36 PM
crazy_eddy
Jun 11, 2006 05:26 PM
downeyballz
Jan 30, 2005 10:10 PM
SPOOLINmatt
Jan 20, 2005 08:39 AM
yellow blur
Mar 11, 2004 11:03 AM
