Ticking noise
Old Jul 23, 2001 | 11:13 PM
quickLSt's Avatar
Default Ticking noise
just recently i have started to hear a ticking noise coming from my motor. it is a very qucik tick, tick, tick, tick. my car seems to be running fine. what might be the problem? how much work and cash will it take to fix?
Old Jul 23, 2001 | 11:37 PM
LostGsr's Avatar
Default Re: Ticking noise (elements150)
If your Honda or Acura has some age to it, then its normal to hear some ticking. If you haven't done a valve adjustment for a while now, then having them adjusted might help solve the problem. Do the adjustment yourself or if its too much trouble for you then bring it in and have a professional do it. It should be around $70.
Old Jul 24, 2001 | 12:32 AM
rivvin's Avatar
New User
Default Re: Ticking noise (LostGsr)
What's the valve adjustment for????
Old Jul 24, 2001 | 05:40 AM
Vracer111's Avatar
Default Re: Ticking noise (rivvin)
The tick-tick-tick-tick noise could also be the timing belt. If it's loose it will make that sound from slapping around near the tensioner pulley I believe. First check to see if the timing belt is loose. Then you could do a valve adjustment just to make sure its in spec.
A valve adjustment is to keep the cam to follower distance within spec - so there isn't too large a gap that the intake and exhaust valves will be slapping against the cam and so there isn't no gap at all which won't allow oil to get between the parts. In short its to help keep the operation of the valves within spec so they don't wear prematurely or get damaged from neglect. On non-VTEC engines it's really easy to do just need the manual, a wrench, a socket and rachet, and a feeler gauge. will take less than one hour to do. VTEC i hear is a little more difficult as you really need a special tool.
[Modified by Vracer111, 6:45 AM 7/24/2001]
Old Jul 24, 2001 | 07:14 AM
mattymatt's Avatar
New User
You might laugh... but out of the blue I started hearing ticking from my car (with the window rolled down). Turns out that there was a stone stuck between the grooves of my tire.
And with respect to the valve adjustment, try the search, it's been well discussed this past month. I just did my first one a week ago without specials tools. It took my 2 hrs the first time, and then 45 minutes the second time (I made a boo boo the first time around.)
scartail
Apr 12, 2007 04:20 AM
sector001
Oct 13, 2006 12:09 PM
lockheedload
Jul 3, 2006 10:25 AM
Dropped90Integra
Feb 22, 2005 01:04 AM
DC2*Integra
Apr 3, 2004 04:14 PM
