Rotor retaining screw
Old Jun 21, 2003 | 11:14 AM
zijiejijeijrkjk's Avatar
Default Rotor retaining screw
How do you get to this? I'm looking at my helms and im staring at the rotor and i cant see how it comes off. Do I have to remove the plastic cover next to the rotor?
Does the screw come up from the bottom?
TIA.
Old Jun 21, 2003 | 11:27 AM
IN VTEC's Avatar
Default Re: Rotor retaining screw (scott_k)
You can't remove the plastic cover until you remove the rotor.
You have to rotate the rotor so that the screw is exposed on the back side where there's an open area on teh plastic cover.
Old Jun 21, 2003 | 01:25 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scott_k &raquo;</TD></TR><TR><TD CLASS="quote">How do you get to this? I'm looking at my helms and im staring at the rotor and i cant see how it comes off. Do I have to remove the plastic cover next to the rotor?
TIA.</TD></TR></TABLE>
Just turn the car over until the retaining screw is visible. It should be pointing towards the firewall if I'm not mistaken.
Old Jun 21, 2003 | 01:59 PM
Default Re: Rotor retaining screw (ActiveAero)
I got da bitch switched out. Seems to be smoother now.
Thanks-
Old Jun 21, 2003 | 04:05 PM
canuck-mx6's Avatar
What ever you do, tighten that screw properly. I had the screw come loose and rattle around. It cracked the case on the ignition control module. Cost from the dealer: $291 CAD for the module. The look on their face when I told them to **** off: priceless
I am still driving around with a slightly messed up ICM, just gonna buy a used disty for about $200 CAD and use the ICM. The worse part is the damn disty has to come out to swap the ICM, so I gotta go borrow a timing light to set my timing
Old Jun 21, 2003 | 04:12 PM
Batoutahell's Avatar
Default Re: Rotor retaining screw (canuck-mx6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 &raquo;</TD></TR><TR><TD CLASS="quote">The worse part is the damn disty has to come out to swap the ICM, so I gotta go borrow a timing light to set my timing </TD></TR></TABLE>
It will not be 100% accurate, but you can scribe marks on the distributor housing so you know how far to rotate the distributor when you reinstall it. Your timing may not be spot-on, but if your marks are accurate enough, I'd be surprised if you're off by more than 1 degree either way. It would be good enough that you could take your time finding a timing gun to borrow.
My ignition coil took a crap last week coming home from the track. I was stranded on the side of the turpike for 3 hours, and had to have the car towed to a friend's father-in-law's house to make the repair. I got a replacement and fixed it in the wee hours of the next morning, and was back at the track for the afternoon sessions. Honda ignition systems blow. Good luck fixing yours.
Old Jul 8, 2003 | 11:03 AM
Leo's Avatar
Leo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 &raquo;</TD></TR><TR><TD CLASS="quote">What ever you do, tighten that screw properly. I had the screw come loose and rattle around. It cracked the case on the ignition control module. Cost from the dealer: $291 CAD for the module. The look on their face when I told them to **** off: priceless
I am still driving around with a slightly messed up ICM, just gonna buy a used disty for about $200 CAD and use the ICM. The worse part is the damn disty has to come out to swap the ICM, so I gotta go borrow a timing light to set my timing </TD></TR></TABLE>
I'm about to do this myself. Should locktite be put on the treads to make it more secure, or will a good tightening down do the trick?????
ReddotsS2K
Honda S2000
Jan 14, 2008 06:26 AM
smoovekriminal
Aug 17, 2007 05:03 PM
Racermech
Nov 14, 2004 04:24 PM
4crx4me
Jun 17, 2003 11:09 PM
b18bvudoo
Dec 12, 2001 08:22 PM
