Which shocks are better???
Banned
I was just wondering, which shocks are better KYB AGXs or Tokico Illuminas? Its weird because the AGXs have 4 way in front and 8 in the back. Does that mean the rear shocks are weaker?
the KYB AGX are a pretty good shock. they have treated me very well wiith no problems. the max lowering on those shocks are something like 1.5 inches. well that's what AGX will cover with the warranty. about the dampening, they are only 4 way adj. in front and 4 way adj. in back, well at least on my 95 ex coupe. hope that helps.
Koni Sports (yellow) are better than both of those.. but if you don't plan on auto-x or track racing, I don't think you 'll see much difference between AGX & Illuminas. Keep in mind both of these shocks are limited to about 400lb spring rates so if you wanted to go up to 450-600lb custom coilover springs, you 'd have to get Koni yellows or other more expensive shocks.
the Koni yellows are still on special here
http://www.diabloautosports.com/prod...roducts_id=367
igone916
Sep 3, 2004 09:35 AM
Jon7
Jul 22, 2001 05:51 PM
