Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Rear sway bar and how to preload/adjust?
Old Jun 20, 2003 | 10:19 PM
ntrinsik's Avatar
Default Rear sway bar and how to preload/adjust?
I posted in the EG+ forum.. no luck getting help there so I thought I'd try the suspension experts here..
I have the S/T rear sway bar and tie bar combo. However, I notice that the passanger side endlink is angled more so than the driver side endlink (this is when the car is on the ground). I think that this (the angle the endlinks make) has something to do with preload on the sway bar, and I made sure the endlinks were the same length when I installed them. The instructions on the install sheet are hard enough to follow, let me tell you that.
Also, what exactly is preload and how would I go about doing it?
Thanks for all the help in advance.
Old Jun 21, 2003 | 01:42 PM
Lo-Buck EF's Avatar
Default Re: Rear sway bar and how to preload/adjust? (ntrinsik)
do a search. this has been discussed.
grandtheftlunchbox
23
Nov 4, 2008 08:06 PM
fongph
Apr 15, 2005 10:18 AM
Andrew 825SM
Jul 7, 2003 01:19 PM
ntrinsik
Jun 17, 2003 06:28 PM
Vinceg99
Jan 10, 2003 10:56 AM
