wirg questions about tachometer
Old Jun 20, 2003 | 03:02 PM
preluder's Avatar
Default wirg questions about tachometer
which wire do i hook the negative feed to the distributor in order to get the feed from so that my tach gets a reading.
Old Jun 20, 2003 | 03:51 PM
caLiH22A's Avatar
Default Re: wirg questions about tachometer (preluder)
the blue wire on your distributor cap is the one that holds the rpm signal.
Old Jun 21, 2003 | 06:08 AM
rjr162's Avatar
Default Re: wirg questions about tachometer (caLiH22A)
or if you dont' want to mess with the wires there, go look at the passenger side of the engine by the shock tower, there's a plug with a single blue wire.. that's the diag plug for your tach and you can tag in over there instead
Old Jun 22, 2003 | 07:26 AM
preluder's Avatar
Default Re: wirg questions about tachometer (rjr162)
okay thanks guys but im looking at the connectors on the distributor and theres two connectors and its the one on the left there are 2 blue wires which one like blue with a white strip.
Old Jun 23, 2003 | 12:46 PM
prelittlelude's Avatar
i didn't bother with running my wires into the engine bay, if you have cruise control look under your dash and find the cruise control unit, it has a tach input wire, solid blue, i tapped off of that, so i didn't have to run it out thru the fire wall
Old Jun 24, 2003 | 06:46 AM
preluder's Avatar
Default Re: wirg questions about tachometer (prelittlelude)
okay is it the same as the honda accord wire hook up?
Old Jun 24, 2003 | 06:49 AM
Nick M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluder &raquo;</TD></TR><TR><TD CLASS="quote">okay is it the same as the honda accord wire hook up? </TD></TR></TABLE>
yes
Old Jun 24, 2003 | 07:19 AM
preluder's Avatar
Default Re: wirg questions about tachometer (Nick M)
thanks now for the timing where should my timing be my sensor is coming now
Old Jun 24, 2003 | 07:21 AM
preluder's Avatar
also another thing uhhhm as for the prelude my h22a uhhhmm should my next step be to build the block up of go turbo and how much am i lookin at. Then which should i step it up to on forced induction a supercharger or a turbo?
Karl Kluth
Oct 19, 2017 09:02 AM
GSRCRXsi
May 22, 2005 08:01 PM
SleepnCiViC
13
Dec 11, 2003 02:59 PM
vrrodri
12
Jul 4, 2002 08:19 AM
89hondarex
Aug 29, 2001 09:42 PM
