How far can i bore a built H23 to?
Old Jun 20, 2003 | 12:05 PM
IloveNewt's Avatar
Default How far can i bore a built H23 to?
My engine blew the hg about 2 weeks ago. Upon tear down we discovered many signs of incompetence from the original builder. I will go further on that once we get everything settled and some pics.
My question right now is, it looks like a re-hone will not cut it with the clearence issues. Looks like i will have to re-bore it. I has a h23 with GE sleeves with stock bore. How far can i bore it to untill i would have to worry about wall thinknesses? Is 2.5l h23 asking too much?
Old Jun 20, 2003 | 12:13 PM
2point6's Avatar
Default Re: How far can i bore a built H23 to? (MordecaiPSI)
IMO, I would go no bigger than 89mm if this is a street car. Any bigger can result in cylinder distortion due to thinner walls, and head gasket sealing issues.
Old Jun 20, 2003 | 12:14 PM
Boostless97Lude
Guest
Posts: n/a
89mm GE sleeved H22A4
you CAN go as big as 90mm
Old Jun 20, 2003 | 12:33 PM
IloveNewt's Avatar
Default Re: How far can i bore a built H23 to? (Boosted97Lude)
Yea im still trying ot keep this car streetable. I dont want the chance of getting the walls too thin. Also liek to leav sumthin there for the future....in case shiit happens, again.
What displacement does a 89mm bore make it?
Old Jun 20, 2003 | 12:37 PM
2point6's Avatar
89mm bore
95mm stroke
= 2364.1 ltr
Old Jun 20, 2003 | 12:41 PM
Boostless97Lude
Guest
Posts: n/a
2.3xxx i think, i dont know, i never actually calculated the displacement, i didn't really plan on going to 89mm but they were the only pistons i could find on short notice, plus i got a deal on them
Old Jun 20, 2003 | 01:12 PM
IloveNewt's Avatar
Hmm. I think i might just bore it as little as ill need to. Seems liek the power increase is negligible...nuthin a little more boost wont handle. And id like to have sumthin there for the future.
Old Jun 20, 2003 | 02:14 PM
satan_srv's Avatar
89mm sleeved H22A4 - 2258cc
Old Jun 20, 2003 | 02:20 PM
PrecisionH23a's Avatar
Default Re: How far can i bore a built H23 to? (satan_srv)
honestly i wouldnt go all the way to a 89mm in case you run into problems down the road. Go about 40 over (88mm) that way if you f your walls up later you can move up to a 50 over piston and so on and so on. Be on the safe side.
hOndafienD 04
Dec 9, 2004 05:51 PM
BoostedH23a1
Jul 19, 2003 10:15 PM
untitled
May 19, 2003 02:06 PM
BoostedH23a1
Apr 10, 2003 06:16 PM
93ludeSi
Mar 12, 2003 04:23 AM
