powershifting with act xtss and prolite flywheel
Old Jun 20, 2003 | 11:22 AM
T3T495GSR's Avatar
Default powershifting with act xtss and prolite flywheel
hey guys, i just got 1000 miles on my new setup (act xtss and act prolite flywheel)
its very hard to shift as fast as i could with the oem, so im wondering if its safe to powershift!!!
the only thing i can see wrong with it is that if i go in the wrong gear , but i do have a revlimiter in case i dont go in a gear, also can my tranny take this?
its a 95 gsr with 8 psi TUNED. can the clutch and flywheel take this abuse? im sure its meant to. THANKS
Old Jun 20, 2003 | 01:35 PM
drvfast's Avatar
Default Re: powershifting with act xtss and prolite flywheel (T3T495GSR)
the clutch can take the abuse. its just personal perfrence. i full throttle most of the time and my tranny is fine. its up to the driver
Old Jun 20, 2003 | 02:02 PM
Kamin's Avatar
it shouldnt be hard to shift....
are you 100% sure your clutch is fully engaging?
Old Jun 21, 2003 | 11:50 AM
preluder's Avatar
Default Re: powershifting with act xtss and prolite flywheel (Kamin)
its okay to powershift just dont do it at full throttle youve been warned. Ive heard nightmares about that.
Old Jun 22, 2003 | 07:45 AM
T3T495GSR's Avatar
Default Re: powershifting with act xtss and prolite flywheel (preluder)
thanks, what kinda nightmares?
Old Jun 22, 2003 | 10:26 AM
eg6h8k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3T495GSR &raquo;</TD></TR><TR><TD CLASS="quote">thanks, what kinda nightmares?</TD></TR></TABLE>
i broke my diff...doing that..it was a nightmare..well for me..
Old Jun 22, 2003 | 10:53 AM
preluder's Avatar
Default Re: powershifting with act xtss and prolite flywheel (eg6h8k)
well first your flywheel can come off i dont know how the hell that happened but it happened to my boy with another h22a and differential can clamp so hard pop do diffy what eg said and all your gears can get shreded. ANd your damn tyranny can fall out we got a customer here who went cryin like he was rapped cause he needed a rethread on the block and a new tranny period and aint no comin up out that.
Old Jun 28, 2003 | 09:16 AM
kaj's Avatar
kaj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluder &raquo;</TD></TR><TR><TD CLASS="quote">well first your flywheel can come off i dont know how the hell that happened but it happened to my boy with another h22a and differential can clamp so hard pop do diffy what eg said and all your gears can get shreded. ANd your damn tyranny can fall out we got a customer here who went cryin like he was rapped cause he needed a rethread on the block and a new tranny period and aint no comin up out that.</TD></TR></TABLE>
what did you say??
Old Jun 28, 2003 | 12:16 PM
JV's Avatar
JV
Who?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">it shouldnt be hard to shift....
are you 100% sure your clutch is fully engaging?</TD></TR></TABLE>
Did you make any clutch pedal adjustments after the install?
I installed the same clutch on my B18B/GSR trannied EX. The pedal pressure and engagment height sucked.
I made a few adjustments to the "pedal", it feels and shifts much smoother now...
Old Jun 28, 2003 | 12:21 PM
MikeSarr_GSR's Avatar
Default Re: powershifting with act xtss and prolite flywheel (JV)
do you really accelerate that much faster powershifting? the spacing on the gears still asks the car to wait to accelerate even after engagement. I would suggest you cut that crap out unless you have a tranny graveyard from which to pull spare parts. this is how hondas develop gears that grind on engagement. shifting too fast for the clutch to create enough pressure to allow the synchros to spin down and engage the gear. full throttle shifting is fun though, I guess you have the hondata setup? remember, if you miss a gear into another lower gear at 8K that rev limiter dont mean a thing.
Old Jun 28, 2003 | 12:35 PM
kaj's Avatar
kaj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV &raquo;</TD></TR><TR><TD CLASS="quote">
I made a few adjustments to the "pedal", it feels and shifts much smoother now...</TD></TR></TABLE>
how did you adjust the pedal??
Old Jun 28, 2003 | 01:24 PM
JV's Avatar
JV
Who?
Default Re: powershifting with act xtss and prolite flywheel (kaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaj &raquo;</TD></TR><TR><TD CLASS="quote">
how did you adjust the pedal??</TD></TR></TABLE>
Boostage
Aug 20, 2006 08:20 AM
96b18c
Mar 2, 2006 01:54 PM
VisPreludeVtec
Sep 8, 2004 04:12 PM
oMek
Jun 12, 2004 12:43 PM
DeDonDeRosa
Jun 13, 2003 02:05 PM
