squeaky clutch
Old Jun 19, 2003 | 09:56 PM
92civeg's Avatar
Default squeaky clutch
how do i get my clutch to stop squeaking its a brand new act street/slip clutch and the majority of the time whenever i push my clutch in and out its squeaks
help!!!!!!!!!!!!!
Old Jun 19, 2003 | 11:57 PM
mtber's Avatar
Default Re: squeaky clutch (92civeg)
check your slave cylinder...
1. bleed it & put new clutch fluid in the lines...
2. check slave cylinder for lube...
3. just listen for the noise and pinpoint it out.
Old Jun 19, 2003 | 11:58 PM
leadfoot78's Avatar
My ACT clutch does it too, some times its a loud screech when I release it quick, I figure it's the bearing not coping wery well with the pressure of the extreme P plate. I'm going to change the clutch soon, I don't like the 6puck.
P.s I alredy replaced my master cylinder and bleed the system to ****, no leaks in the slave cycinder either.
Old Jun 20, 2003 | 06:10 AM
Frankie324's Avatar
Default Re: squeaky clutch (leadfoot78)
its normal. you will get used to it, its funny because i thought it went away but when i let someone else drive it it scratches and makes crazy sounds.
Old Jun 20, 2003 | 09:02 AM
ACTman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civeg &raquo;</TD></TR><TR><TD CLASS="quote">how do i get my clutch to stop squeaking its a brand new act street/slip clutch and the majority of the time whenever i push my clutch in and out its squeaks</TD></TR></TABLE>
I have heard of squeak sounds with the puck disc but not with the street disc. Is this sound associated with the pedal movement or slipping of the clutch? If it is pedal movement, the linkage probably wasn't lubricated properly with the new clutch install. Usually a squeak will occur if the clutch arm pivot ball or slave cylinder rod end is not lubricated. I would check these areas first.
Old Jun 20, 2003 | 09:15 PM
92civeg's Avatar
Default Re: squeaky clutch (ACTman)
please post some pics of what movinng parts need to be luburicated like the fork and other moving parts........... thanks
Old Jun 22, 2003 | 09:49 PM
ACTman's Avatar
I am sorry but I don't have anything like that to show you and I will be out of town all week.
Old Jun 22, 2003 | 11:05 PM
Malgerus's Avatar
Yeah, my freaking ACT heavy duty groans when I ride the clutch!
Old Jun 23, 2003 | 07:08 AM
eg6h8k's Avatar
Default Re: squeaky clutch (Mr. S)
hmm did u put some grease where the throw out bearing goes in..and the little ball where the clutch fork hooks onto..?
Old Jun 23, 2003 | 09:04 PM
92civeg's Avatar
Default Re: squeaky clutch (eg6h8k)
no, i havent greased it up im gonna try though ..what kind of grease should i use and the throw out bearing is just inside the rubber boot that the clutch fork moves in correct????
Old Jun 23, 2003 | 09:53 PM
Neptune's Avatar
Wow, my stock clutch does the same thing. It has been squeaking for a while. Mostly when it is very humid outside. Friends civic does that too. Maybe it is because of a leak in the tranny where moister can get in or something? Doesn't hurt performance does it?
Old Jun 23, 2003 | 11:07 PM
VtecDA9's Avatar
My ACT 6 puc HDPP sounds like i'm scrtchign a chalk board (kinda) if I don't let it out right.... i ahve to ride it softly, either that or immediatley engage at 3500 rpm which is horrible... But I still like it.
Old Jun 24, 2003 | 03:02 AM
irev210's Avatar
help!!!!!!!!!!!!! </TD></TR></TABLE>
It sounds like the shaft the throwout bearing slides on. Use a moly based lube to lubricate the shaft for it to slide in and out easily. Every time you drop the tranny, you should lubricate the shaft to insure a squeek free setup. If you didnt have it on a stock pp, it was because the force required to push down the pp wasnt as great as your new ACT. More force=greater pressure on the shaft, hence a small squeek.
Basicly, the throwout bearing slides on the shaft, the lube wears out after age and is even a more noticed problem with higher strength p/p's.
There is some special honda moly base lube that honda uses.
I use moly base assembely lube which is good up to about 350 degrees.
When looking for one, try to find one with the highest temp stability.
Old Jun 25, 2003 | 10:23 AM
92civeg's Avatar
Default Re: squeaky clutch (irev210)
ok i bought a moly based grease and put it between where the fork and the shaft connect in the boot mabye i didnt use enough but it still squeaks
any thoughts
Old Jun 25, 2003 | 01:33 PM
irev210's Avatar
that does no good
its the shaft that the throwout bearing slides along.
the only way you can get to it is if the tranny is off the car
Old Jun 25, 2003 | 01:49 PM
Mr. Vapor's Avatar
my Exedy clutch and PP do the same.........i think its the slave
Old Jun 25, 2003 | 07:21 PM
92civeg's Avatar
Default Re: squeaky clutch (Mr. Vapor)
so how do i stop it???
Old Jun 26, 2003 | 09:10 PM
92civeg's Avatar
Old Jun 27, 2003 | 09:47 PM
92civeg's Avatar
Old Jun 27, 2003 | 09:49 PM
simple4012's Avatar
New User
throwout bearing. Im guessing when the car is off you can really hear it. like when you go to start it. just ya throwout bearing. if ya clutch still grabs and feels ok leave it.
my .02
Old Jun 29, 2003 | 10:39 AM
92civeg's Avatar
Default Re: squeaky clutch (simple4012)
theres nothing i can do about it??
Old Jun 29, 2003 | 12:49 PM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simple4012 &raquo;</TD></TR><TR><TD CLASS="quote">throwout bearing. Im guessing when the car is off you can really hear it. like when you go to start it. just ya throwout bearing. if ya clutch still grabs and feels ok leave it.
my .02</TD></TR></TABLE>
yup
If it is comming from under the dash or somewhere else, then its obviously not that, but if its comming from the tranny, thats where its comming from.
nuttin u can do about it unless u drop the tranny.
its not bad, just annoying.
Felt.2
Aug 13, 2006 03:47 PM
jerBEAR
Aug 14, 2005 11:18 PM
ibe2fly
Jul 10, 2004 03:31 PM
civcexcoupeblack
Aug 25, 2003 07:21 PM
KooK
Jul 11, 2002 03:28 AM
