Cam plate torque specs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">dont know where u got ur specs 3rdgteg but i read myne outa haynes page 2b-2</TD></TR></TABLE>straight out of the "HELM'S Manual" for the Integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">lol, you sure you got the specs for a b18c1 and not a b18b ?</TD></TR></TABLE>does ur "haynes manual" show "cam plates" for a b18b???? If it does, then there's your problem right there........buy a real manual.
Besides...what's the difference between 7.2 ft. lbs. and 86 in. lbs. anyway? Isn't it approximately the same; he knows there are only two sizes of bolts that holds the damn cam plates down....and one is approx. 7ft. lbs. and the bigger bolt is 20ft lbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdGteg »</TD></TR><TR><TD CLASS="quote">20 ft. lbs. --> for the 12mm bolts
7.2 ft. lbs. --> for the 10mm bolts</TD></TR></TABLE>
i usually tq the 12mm to 20ft lb
and 10mm to 10ft lb
and 10mm to 10ft lb
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">according to haynes its...
camshaft holer bolt torque specs:
b18c1
6mm bolts - 86 in-lbs
8mm bolts 20 ft lbs
see i have a chilton
and here is the problem
there are no 6 or 8 mm bolts. it says that same ****.
so i ask HT
but thanks guys. i appreciate it.
b18c1
8mm bolts 20 ft lbs
so i ask HT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">
The heads are 10mm and 12mm, but the bolt size is measured by the shaft size, not the head size. My Helms shows all hardware as shaft size x thread pitch, like 6 x 1.25.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94CivicSi »</TD></TR><TR><TD CLASS="quote">
The heads are 10mm and 12mm, but the bolt size is measured by the shaft size, not the head size. My Helms shows all hardware as shaft size x thread pitch, like 6 x 1.25. </TD></TR></TABLE>My Helm's does too, but since I've torqued those stupid bolts about a thousand times, I just tend to translate those shaft size x thread pitch to the head size (the socket I use)....much easier.
The helms manual torque specs are too high.
Do 18lbs on the 12mm bolts.
