took off header. lots of carbon build up.. safe to clean?
Old Jun 19, 2003 | 08:58 PM
MachAF's Avatar
Default took off header. lots of carbon build up.. safe to clean?
I took off my header and see that there is lots of carbon build up on the exhaust valve exit. Is it okay to scrape it all off? Spray it with some simple green to clean it?
Thanks
Old Jun 19, 2003 | 11:57 PM
mtber's Avatar
use some brake cleaner from your local parts store and a rag...
Old Jun 20, 2003 | 12:04 AM
leadfoot78's Avatar
Default Re: took off header. lots of carbon build up.. safe to clean? (MachAF)
I wouldn't spray any detergents inside my head, oil and degreasers dont mix well. It will wash the oil of your cylinder walls and thats never good. I had the same problem but I took the head of and took out the valves.
Old Jun 20, 2003 | 07:14 AM
Moe's Avatar
Moe
Default Re: took off header. lots of carbon build up.. safe to clean? (leadfoot78)
^ Im with him.
Ask youself this, what does it matter, your gonna get more cabon build up when you start driving again, so it really doesnt matter. Like that pretty pressure plate on you clutch, that you willl never see, it doesnt make sense to me.
Old Jun 20, 2003 | 08:32 AM
drumking15's Avatar
actaully it wont do ****....#1 your exhuats valves should be closed.....if there open then done spray it down there...but get a rag and some degreaser and put the degreaaser on the rag...dont spray it....then wipe away all the carbon build up, if needed use a small brass birstle brush to help loosen some of the crap...then make sure it relatively dry...and bolt it all back up
stevescivic
Aug 31, 2006 10:14 PM
Got_soy
May 15, 2006 05:54 AM
PreStaged12s
22
Jun 17, 2005 07:51 PM
M0NEYnH0s
Apr 26, 2002 01:24 PM
