Y8 IM questions....
Old Jun 19, 2003 | 04:27 PM
ImportHatch's Avatar
Default Y8 IM questions....
Ok, im having some problems figuring out where stuff goes. This is a Y8 intake manifold on a z6. Can I do the following for coolant and bypass the TB and IAC???
And also on this pic, Where do I run the EVAC/PURGE Vacuum source to, or can I plug it off.
Thanks in advance.
Yager-
Old Jun 19, 2003 | 05:51 PM
MrTodd's Avatar
Default Re: Y8 IM questions.... (ImportHatch)
Yeah, I suppose you could run the coolant lines bypassed like that. Just double check it before and after you setup the lines.
As for the Purge nipple on the front of the Y8 manifold, you should cap it off if you're not using the Y8 purge solenoid (which you shouldn't unless you have OBD-2). I capped off mine, and set up a Z6 style purge assembly.
Old Jun 19, 2003 | 07:23 PM
Default Re: Y8 IM questions.... (MrTodd)
nevermind. I gave up.
Yager-
StuckInTexas
Feb 12, 2015 10:38 PM
Red_ED8
Apr 30, 2008 05:22 AM
^Sammy]!.
Dec 30, 2004 05:52 AM
92civic_eg
Aug 18, 2004 06:24 PM
ImportHatch
Jun 19, 2003 04:56 PM
