CRV Spindles will they fit Type R?
I know there both 5 lug. I bought a 5 lug conversion and one of the sides is really bent. I wondering If I could use a crv spindle. thanks guys
Modified by Solo2Vtec at 1:31 AM 6/20/2003
What exactly is bent. The spindle is referred to as the steering knuckle. If it is that no the crv will not fit. The hub is the part with the 5 lugs and the bearing that also attaches to the steering knuckle. HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R »</TD></TR><TR><TD CLASS="quote">
if the bolt pattern matches, it should work, right?</TD></TR></TABLE>
I think its a little more complex than that...
height
ball joint size
track width
camber/caster position
etc...
height
ball joint size
track width
etc...
Well ok aside from the exact measurments( which i intend to get) the crv was based off a Bseries platform for the most part....I have admired a crx when i was working on one for a hour or so (lol). but for instance their is a brace that extenbds from where one tow hook is to another... yep gonna buy one for my civic.... I maybe wrong but I am preety sure the steering knuckle from the upper ball joint to the lower ball joint is the same cause i thought about getting one off a crv or oddesey and useing it to make a psudeo "type r 5lug conversion" . the rear would be easy as the spindle seperates from the R. traling arm with a 50 torks head for the 4 bolts. Thus you could order a type r spindle (would have the holes for the caliper bracket) and hub/rotor and possible gsr rear caliper.... maybe just wishfull thinking...
macrosshn
Dec 27, 2004 08:59 PM
