water in trunk! Is it normal.
Old Jun 19, 2003 | 02:33 PM
4doorturbo's Avatar
Default water in trunk! Is it normal.
Just wana know. i have 97 4door integra!
Old Jun 19, 2003 | 02:35 PM
si foo's Avatar
Default Re: water in trunk! Is it normal. (4doorturbo)
yes if u have fish living in it. water should be leaking from the tail light.
Old Jun 19, 2003 | 02:44 PM
pineapplemike's Avatar
yeah i have the problem too sometimes. 94 integ 4 door
4doorturbo's Avatar
lol!
Old Jun 19, 2003 | 02:45 PM
AllmotorJunkie's Avatar
drill a hole in the spare tire compartment to drain out the water.
Old Jun 19, 2003 | 02:50 PM
Behan's Avatar
Default Re: water in trunk! Is it normal. (AllmotorJunkie)
your leak is most likely in your window seals, you can either pay to have them fixed or drill a hole
si foo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllmotorJunkie &raquo;</TD></TR><TR><TD CLASS="quote">drill a hole in the spare tire compartment to drain out the water. </TD></TR></TABLE>
lol don't think it's too smart. Just change a new gasket behind the tail light, that rubber thing.
Old Jun 19, 2003 | 02:52 PM
Behan's Avatar
Default Re: water in trunk! Is it normal. (si foo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si foo &raquo;</TD></TR><TR><TD CLASS="quote">
lol don't think it's too smart. Just change a new gasket behind the tail light, that rubber thing.</TD></TR></TABLE>
its not smart or the correct way but it will fix the problem. although you may have a problem with water splashing back up through the hole.
Old Jun 19, 2003 | 03:21 PM
Dased530's Avatar
Default Re: water in trunk! Is it normal. (93preludevtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludevtec &raquo;</TD></TR><TR><TD CLASS="quote">
its not smart or the correct way but it will fix the problem. although you may have a problem with water splashing back up through the hole. </TD></TR></TABLE>
yeah if you go driving around in rivers,....
theres a how to for that fix on team integra
Old Jun 19, 2003 | 03:50 PM
4DooRGiSzer's Avatar
Default Re: water in trunk! Is it normal. (Dased530)
wow i have this problem too. ive been wondering what to do about it too. i have seriously had over a gallon of water in my trunk before, from some leak. i thought i was the only four door with this problem, guess not..
Old Jun 19, 2003 | 04:28 PM
tsands's Avatar
Default Re: water in trunk! Is it normal. (4DooRGiSzer)
i had this problem in an 87 ls. thought it was just worn out seals around hatch. no longer mine, so who cares. lol. i would start with the window seals.
Old Jun 19, 2003 | 04:41 PM
ragejed's Avatar
Default Re: water in trunk! Is it normal. (tsands)
Just to let you guys know, I sell replacement taillight gaskets for your integras. (Generation 2, 94-2001) 2 door, and 4 door. I have a handfull ready to ship. Check the link in my sig, and PM if you wold like to buy a set.
Old Jun 19, 2003 | 06:56 PM
SMZ GSR's Avatar
Default Re: water in trunk! Is it normal. (ragejed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed &raquo;</TD></TR><TR><TD CLASS="quote">Just to let you guys know, I sell replacement taillight gaskets for your integras. (Generation 2, 94-2001) 2 door, and 4 door. I have a handfull ready to ship. Check the link in my sig, and PM if you wold like to buy a set.</TD></TR></TABLE>
i've bought them for my integra and have no more water in the taillights
Old Jun 19, 2003 | 07:10 PM
legitracer's Avatar
it leaks in through the power antenna
Old Jun 19, 2003 | 07:29 PM
Mikey's Avatar
Default Re: water in trunk! Is it normal. (SMZ GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMZ GSR &raquo;</TD></TR><TR><TD CLASS="quote">
i've bought them for my integra and have no more water in the taillights </TD></TR></TABLE>
Me too! The new taillight gaskets fixed the swimming pool in my trunk.
Old Jun 19, 2003 | 08:23 PM
ragejed's Avatar
Default Re: water in trunk! Is it normal. (Mikey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey &raquo;</TD></TR><TR><TD CLASS="quote">
Me too! The new taillight gaskets fixed the swimming pool in my trunk.</TD></TR></TABLE>
Glad to hear everyone likes them
Old Jun 19, 2003 | 08:30 PM
Moe's Avatar
Moe
The car leaks naturally, if you look. Theres like a little pocket on teh side, for the cabin to breath, if you are running around with a stripped interior, chances are thats the reason your leaking water.
Or the window or tailight seals from the hatch as well.
Old Jun 19, 2003 | 09:00 PM
ragejed's Avatar
Default Re: water in trunk! Is it normal. (Moe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moe &raquo;</TD></TR><TR><TD CLASS="quote">The car leaks naturally, if you look. Theres like a little pocket on teh side, for the cabin to breath, if you are running around with a stripped interior, chances are thats the reason your leaking water.
Or the window or tailight seals from the hatch as well.</TD></TR></TABLE>
My car doesnt leak..
Old Jun 19, 2003 | 09:40 PM
X2BOARD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moe &raquo;</TD></TR><TR><TD CLASS="quote">The car leaks naturally, if you look. Theres like a little pocket on teh side, for the cabin to breath, .....</TD></TR></TABLE>
That breather does not leak inside the car unless you drive thru a flood. It is well tucked into the bumper.
X2
Old Jun 19, 2003 | 10:19 PM
Audio28's Avatar
omg, i thought i was the only one out there with this problem. I too, have had at least a gallon in my trunk. I guess I'm gonna be ordering some gaskets from ragejed to get this fixed. Thanks for this thread, i've been seriously lagging about getting this fixed.
Old Jun 19, 2003 | 10:40 PM
integraver's Avatar
Default Re: water in trunk! Is it normal. (Audio28)
firdlty the question is soo tyte hehe .. he ask IS IT NORMAL ? hehe honeslty it is as integrs alwasy that happenss hehe .. is it normall man u crazy guy dude.. hehe take care... and no just get a sponge and get the water out.. change the taillgith rubber.. i got many want a new one come pikc it up hehe.. later man is it normal ? hehee i like it bbye .. 4 lifer
Old Jun 19, 2003 | 11:55 PM
pr0jektdc2's Avatar
Default Re: water in trunk! Is it normal. (integraver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraver &raquo;</TD></TR><TR><TD CLASS="quote">firdlty the question is soo tyte hehe .. he ask IS IT NORMAL ? hehe honeslty it is as integrs alwasy that happenss hehe .. is it normall man u crazy guy dude.. hehe take care... and no just get a sponge and get the water out.. change the taillgith rubber.. i got many want a new one come pikc it up hehe.. later man is it normal ? hehee i like it bbye .. 4 lifer</TD></TR></TABLE>
SPELL CHECK IS YOUR FRIEND!!!!!!!!!!!
Old Jun 20, 2003 | 03:20 AM
ebelp's Avatar
Default Re: water in trunk! Is it normal. (pr0jektdc2)
I can vouch for ragejed. His taillight gaskets are top notch.
Old Jun 20, 2003 | 05:08 AM
Project SSAP1's Avatar
Glad to hear everyone likes them </TD></TR></TABLE>
I bought from RAGEJED too..great gaskets and very thick..my leak went away i was so damn happy casue i would have a pool in the hatch everytime it rained..i had to drill a hole first to get rid of the water
Old Jun 20, 2003 | 05:22 AM
grlstockb18c1's Avatar
when i went to change my back lights, there was a puddle in my trunk also....
