can someone tell me which wire is which?
Old Jun 19, 2003 | 02:05 PM
jonoknut's Avatar
Default can someone tell me which wire is which?
i need to know which wire here is the power from the antenna..there is a power line, and there is the radio signal line. . the two black ones at the top and bottom are the ones i believe are them, but does anyone know which is which?? thanks a lot.
Old Jun 19, 2003 | 02:17 PM
PHAT-INTEGRA's Avatar
Default Re: can someone tell me which wire is which? (jonoknut)
G3 Acura Integra
12V|White|+|Ignition Harness
Starter|Black/White|+|Ignition Harness
Ignition|Black/Yellow|+|Ignition Harness
Accessory|Yellow|+|Ignition Harness
Power-Lock|Black/White|-|Drivers Kick Panel *2
Power-Unlock|Black/Red|-|Drivers Kick Panel *2
Parking Lights|Red/Black|+|Green Plug Above Fuse Box *3
Headlights|Red/White(low)12awg|+|Steering Column
Door Trigger|Lt.Green/Red|-|Drivers Kick Panel *2 *4
Dome Supervision|Use Door Trigger
Trunk/Hatch Pin|Green|-| *6
Trunk/Hatch Release|Blue|-|At Switch *7
Tachometer|Blue|Distributor *1
Brake Wire|Green/White|+|Brake Switch
Horn Trigger|Grey or Blue/Green|-|Steering Column
Wipers|Blue & Blue/Yellow|-|Steering Column *5
LF Window Up-Dn|Red/Blue-Red/Yellow|A|In Drivers Door
RF Window Up-Dn|Blue/Green-Blue/Yellow|A|In Drivers Door or DKP
LR Window Up-Dn|Green-Green/Yellow|A|In Drivers Door or DKP
RR Window Up-Dn|Yellow/Green-Yellow|A|In Drivers Door or DKP
Sun Roof Open-Close|Green/Red-Green/Yellow|A|Sun Roof Switch
Radio 12V|White/Blue|+|Radio
Radio Ground|Black|-|Radio
Radio Switch|Yellow/Red|+|Radio
Radio Illuminate|Red/Black|+|Radio
Power Antenna|Yellow/Green|+|Radio
LF Speaker|Blue/Green-Grey/Black|Radio
RF Speaker|Red/Green-Brown/Black|Radio
LR Speaker|Blue/Yellow-Grey/White|Radio
RR Speaker|Red/Yellow-Brown/White|Radio
Old Jun 19, 2003 | 02:33 PM
jonoknut's Avatar
Default Re: can someone tell me which wire is which? (PHAT-INTEGRA)
alright. . well all i wanted to do is have the power stop cus the antennea onwt move wherever i have it.. with the motor anyways . .so while waiting for some repsonses i went ahead and tried pulling one of the plugs and testing the radio. . sure enough the power didnt work on the antenna. . no struggling noises, and my antennea is neatly perched at about 6 or 7 inches. . hey it looks better to me. . its like a silver s2k one. .heh/. /. and the radio doesnt work any differenlty. . so thats deifntely cool. . anyways. . that problems over with. . .
Old Jun 19, 2003 | 02:57 PM
si foo's Avatar
This one goes here and that one goes there, see
Old Jun 19, 2003 | 04:15 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Just in case you still want to know, there is a yellow/green wire coming from the radio harness, this is the signal that tells the antenna when the radio is on. The actual power to move the motor comes from the white/red wire, which comes from the No. 3 (7.5A) fuse underneath the dash.
EFPimpin
Audio / Security / Video
Sep 17, 2010 03:55 AM
Hanmin
Sep 19, 2008 06:07 AM
4EN[sic]
Mar 9, 2007 05:09 AM
forced
Oct 14, 2002 08:46 PM
