When is it time to change spark plug wires?
Old Jun 19, 2003 | 01:13 PM
B18Redline's Avatar
Default When is it time to change spark plug wires?
What do you look for? Discoloration?.....because mine are sorta brownish.
Old Jun 19, 2003 | 01:40 PM
JimBlake's Avatar
Default Re: When is it time to change spark plug wires? (Redline07)
Check resistance with an ohm-meter, that's one way for them to fail.
They can fail by the insulation 'leaking' your spark out. Wait till dark, completely cold engine, take off sparkplug cover, turn off all the lights. Start engine & look for arcing. Sometimes when they arc like this I can't see any visible damage..
Old Jun 19, 2003 | 02:58 PM
TEG98's Avatar
Default Re: When is it time to change spark plug wires? (JimBlake)
they also should be changed if you can see any damage to the wire insulation or corrosion
Old Jun 19, 2003 | 03:42 PM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Check resistance with an ohm-meter, that's one way for them to fail.
visible dammage is a grayish color on the isulation.
Mik2006
Jul 31, 2009 02:54 PM
matmcg
Feb 17, 2008 02:06 AM
vinuneuro
Oct 3, 2006 01:26 PM
sleepystyle
Sep 24, 2006 07:34 PM
vxnine
Oct 12, 2004 04:27 PM
