how do I remove rear windows in 2dr GSR?? Need to get them out to sell them
Old Jun 19, 2003 | 10:26 AM
SleepyEG's Avatar
Default how do I remove rear windows in 2dr GSR?? Need to get them out to sell them
yup. That's the question
~james
Old Jun 19, 2003 | 12:19 PM
redlinegsr's Avatar
Default Re: how do I remove rear windows in 2dr GSR?? Need to get them out to sell them (SleepyEG)
You have to pull the rubber edging off from the outside of the window. It will feel like it doesnt want to come off but it will with a little yankage lol. once that is off you have to slowly pry like you would on a windsheild until the adhesive gives and wallah its done. It a pain in the *** process though
Old Jun 19, 2003 | 08:53 PM
SleepyEG's Avatar
Default Re: how do I remove rear windows in 2dr GSR?? Need to get them out to sell them (redlinegsr)
well the outside stuff didn't really come off, even with razor blade, and a lot of pulling.....got some of it off, but the window isn't budging..Any other suggestions?
~james
Old Jun 20, 2003 | 10:05 AM
SleepyEG's Avatar
ANYBODY?
Old Jun 20, 2003 | 11:25 AM
escalade30's Avatar
I had to take them out when I got my car repainted. You need to get something some long and slender almost like a coat hanger but skinnier. You need to use this like a snake. Take out the plastic around the window on the inside of the car. Next slide the snake between the plastic weather stripping and car metal on the outside of the car. Then work it through the seal/adhesive holding the window inand push through sosnake goes into the car then attach small metal wire to end of snake and pull back through so that wire protrudes on inside and outside of car. hold wire on both sides and work back and forth acting as a knife as you pull it along the window. this should slice the seal and thewindow should push out.
89hatcher
Mar 5, 2007 08:51 AM
VRD^don
Jul 19, 2006 10:42 AM
Kimbo
11
Mar 31, 2004 12:01 PM
RiCE On IcE 2
Sep 10, 2002 12:47 PM
gokuson
Jun 21, 2002 01:24 PM
