car shakes after 20mph
Old Jun 19, 2003 | 05:50 AM
wizzards581's Avatar
Default car shakes after 20mph
i have 91 LS with act 6puckxtrm... test drove it for awhile after awhile my car starts to shake so much after 20mph now. doesnt seem to be safe to drive.. wats the cause.. im confused now.. mounts look normally... could it be my axles?
Old Jun 19, 2003 | 06:00 AM
MooreBoost's Avatar
Default Re: car shakes after 20mph (wizzards581)
Check all the lugs on your tires, and maybe try an alignment. I dunno, for it to rattle so low I think its something rather obvious, but major, like tires or something.
gmoore
Old Jun 19, 2003 | 08:05 AM
integerkgsr's Avatar
I would say check your lugnuts too. same thing happened to me. forgot to tighen some of 'em.
Old Jun 19, 2003 | 08:13 AM
dohc-nyne's Avatar
is ur car lowered? i recently broke an axle from having a act clutch 6puck and having cambered front wheels
Old Jun 19, 2003 | 08:38 AM
importimage's Avatar
Default Re: (dohc-nyne)
probably wheel nuts. Check the spindle nut also on the hub assembly in the front and rear. If that nut comes out...while you are driving...ugly!!!!
Old Jun 19, 2003 | 09:23 AM
Si Integra's Avatar
I say the axles are prolly the culprit if the lug nuts are tightened. may also be a ball joint?
Old Jun 19, 2003 | 06:29 PM
Default Re: (Si Integra)
actually the car ran fine after installed.. drove it over 500miles already.. and then i finally hit it... now starts to shake... changed new rims on it with newer tires and still does the same... i notice a alittle bolt broke out... where else should i check?
8dxhatchy8
May 7, 2011 06:04 PM
honda305
Mar 4, 2010 09:04 AM
acuralovar
Jun 20, 2009 11:38 PM
phoshizzle88
Feb 20, 2006 09:19 PM
peacexisxfree
Aug 24, 2004 03:17 PM
