Why won't engine manually crank freely?
Old Jun 18, 2003 | 03:59 PM
V8 BAIT's Avatar
Default Why won't engine manually crank freely?
And don't say 'take out the spark plugs' if that is the best you can think of!
I have a mildly built 98 gsr motor ( JE 9.8:1 / Crower rods / ACL bearings ) and ever since it has had the aftermarket rods, pistons, rings, bearings, etc. it is VERY difficult to turn the motor over manually @ the crank pulley and I need to know what the main possibilities are.
Has this happened to anyone else?
Also, after I initially break it free after sitting it will continue to turn freely if it doesn't sit for a long time. Normal or not?
Thanks for any suggestions!
Old Jun 18, 2003 | 04:21 PM
Rocket's Avatar
Default Re: Why won't engine manually crank freely? (V8 BAIT)
Brooks,
Check your clearances. If your clearances are fine then your main bores may have some misalignment. What your are describing is what I call stiction. You have to break it loose to turn the crank but onces turning it's free.
Ideally the crank should spin freelly and come to a gradual stop. If you spin it and it abruptly stops this is signs that your mains or crank is not straight.
You may want to have your machine shop check the crank for straightness and the main bores for straightness.
Your making decent power (and heat) so this is more likely to occur.
Old Jun 18, 2003 | 04:25 PM
V8 BAIT's Avatar
Default Re: Why won't engine manually crank freely? (Rocket)
Thanks for the suggestions, Rocket.
Old Jun 21, 2003 | 06:22 PM
servion's Avatar
Bump. I am having a similiar problem.
Z0831xiz
Apr 26, 2015 03:56 PM
EFPhilly
43
Jan 12, 2010 08:52 AM
huge230
Feb 15, 2008 08:44 AM
Wasabithegosu
May 30, 2005 02:23 PM
hondaeg8
Feb 9, 2004 10:42 AM
