door lock broken... opps
Old Jun 18, 2003 | 12:28 PM
.Noah Fecks's Avatar
Default door lock broken... opps
ok so i locked my dumb self out of my car. not to worry, i did it a few weeks back and watched the triple a man open it and saw his tool. so i made one out of a coat hanger. 4 minutes later im in my car again . bad part is now the door wont lock. the button moves but even int he lock position its not locked. should i take it apart? or is it something more easy.
Old Jun 18, 2003 | 12:33 PM
Home Skillet's Avatar
Default Re: door lock broken... opps (Noah *****)
Take the door panel off and see if any of the door rods are disconnected.
Old Jun 18, 2003 | 12:35 PM
Default Re: door lock broken... opps (Home Skillet)
i dont have a tool to get the window crank off the door know anything ghetto fab to get it off. something else. ill be tempted to remove the seatbelt.
Old Jun 18, 2003 | 12:36 PM
uszcrx's Avatar
just use a rag or something.. you can even do it w/ a flathead.
Old Jun 18, 2003 | 12:39 PM
Default Re: door lock broken... opps (uszcrx)
which side is the clip on? in other words... should i go from the side with the handle or the opposite of the handle.
Old Jun 18, 2003 | 12:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noah ***** &raquo;</TD></TR><TR><TD CLASS="quote">i dont have a tool to get the window crank off the door know anything ghetto fab to get it off. something else. ill be tempted to remove the seatbelt.</TD></TR></TABLE>
Do you have a pick tool? I use that all the time and never use the "proper" door handle remover.
Old Jun 18, 2003 | 01:11 PM
ccjb100's Avatar
Just straighten out a paper clip, then bend one end into a small "hook" shape. Should be able to pull that clip right out without much trouble....
Old Jun 18, 2003 | 01:40 PM
Jay J's Avatar
Prince of Zamunda
Default Re: door lock broken... opps (ccjb100)
go to autozone and get the door crank popper
Old Jun 18, 2003 | 01:42 PM
DJ_SaNdOz's Avatar
i've always just used a screw driver & never had trouble, just pull the handle out some & look down between the handle & the door & you should see the clip. hth
Default Re: door lock broken... opps (neuspeed)
ok i got it all fixed. i yanked kind of hard and bent the rod. i bent it back and its all fixed.
Old Jun 18, 2003 | 01:45 PM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noah ***** &raquo;</TD></TR><TR><TD CLASS="quote">ok i got it all fixed. i yanked kind of hard and bent the rod. i bent it back and its all fixed.</TD></TR></TABLE>
that always works too lol
Old Jun 18, 2003 | 01:51 PM
Default Re: door lock broken... opps (DJ_SaNdOz)
then while i was in there i took out the seat belt. 6.5 pounds but it keeps beeping.
Old Jun 18, 2003 | 02:24 PM
RCautoworks's Avatar
Use pliers next time.
Old Jun 18, 2003 | 03:47 PM
dan89crxsi's Avatar
Default Re: door lock broken... opps (90blackcrx)
how did you get the seatbelt off is yours on the door.......Not just the seatbelt mechanism behind the door panel but the entire seatbelt assembly from where it is up on the top corner of the door without cutting the seatbelt ofcourse
lalaine17
May 4, 2006 05:18 PM
zoolander
Mar 5, 2006 08:22 PM
CWBETB
12
Jul 1, 2005 07:18 AM
kniob
Mar 27, 2004 03:06 PM
ruiner17
10
Sep 8, 2003 11:59 AM
