-Jun Integ = expenisive gas ?-
im now ready to install:
Jun type 3 cams
Jun Valvetrain
Jun Valvesprings
Jun Retainers
Toda Timing Belt
now im facing a new concern... would this setup force me to use higher octane gas? true or false or can i continue using the 91 octane gas premium level?
Jun type 3 cams
Jun Valvetrain
Jun Valvesprings
Jun Retainers
Toda Timing Belt
are you raising the compression ratio???normally higher octane would be needed in higher boost conditions or higher compression......i think you will be ok on normal 91 but if you hear any knocking then its time to step up....too bad you cant get 93....
octane has to do with how slowly the fuel burns off not power.
octane has to do with how slowly the fuel burns off not power.Thread
chrisdansin
Jan 24, 2004 04:15 PM
C4wrx
Dec 30, 2001 06:30 PM
