how do i get rid of this....??¿
Old Jun 18, 2003 | 12:41 AM
gumbii's Avatar
Default how do i get rid of this....??¿
how do i get rid of this.... its a ZC motor, but its using the SI wireing harness and distributer.... i have the ZC distributor.... but i dont feel like taking it to a shop so they can rewire the whole chet..... is there any way i can keep the SI dizzy, and lose the clamp...??¿
Old Jun 18, 2003 | 12:43 AM
poison's Avatar
Default Re: how do i get rid of this....??¿ (gumbii)
wtf??
That should be held on by a 12mm bolt. I would NOT recommend you drive on that very much longer.
If the threading is stripped, replace the cap on there that is held by two 10 mm bolts that you can see in that picture.
Old Jun 18, 2003 | 12:50 AM
gumbii's Avatar
i took the pics at the wrong angle.... its a huge difference... the top bolt doesnt match up.... theres like a inch difference.... and the other 2 holes dont match up at all.... and ive had it like this for the past 5 months.... i've taken this beater all over the place..... the clamp has never failled.... but it just looks tacky..... but the clamp ownz.....
Old Jun 18, 2003 | 12:52 AM
poison's Avatar
Default Re: (gumbii)
lol ya.
I am not too sure if the Si dizzy will work. But it should.
I would definitely hit up the EF forum. You should have the morning EF crew tap into that a lot faster.
Old Jun 18, 2003 | 12:55 AM
gumbii's Avatar
thanks.... i guess....
Old Jun 18, 2003 | 12:58 AM
gumbii's Avatar
oh... and last week... the waterpump messed up, and took out about 10 teeth off the timing belt.... we thought that parts from a older model integra would fit... the ones with a 1.6... but no luck... i got the water pump from a 89 civic SI.... and the timing belt from a 86-89 2.0 prelude..... the guy at auto zone cross refrenced the numbers on the timing belt....... what a mission...
Old Jun 18, 2003 | 01:04 AM
poison's Avatar
ZC parts are definitely a pain the *** to find.
Old Jun 18, 2003 | 05:04 PM
gumbii's Avatar
bump........
any body else...?¿¿¿
Old Jun 18, 2003 | 05:21 PM
blackhatchy's Avatar
i have never seen that before........
Old Jun 18, 2003 | 06:59 PM
Mohudsolo's Avatar
Default Re: (blackhatchy)
It's hard to tell from the pics, but is there a big enough flat spot on the dist base to drill another hole that matches the mount on the motor? What else does the mount that bolts to the motor do? Could you add a spacer under it to boost it up? Get someone to weld another piece onto the end of the mount?
Old Jun 18, 2003 | 11:33 PM
gumbii's Avatar
wow... drilling another hole is a great idea.... but it sounds like a mission....
some one once told me to get that part from a LS motor... the part that the top bolt bolts onto the heads.... what¿?... you know how it can be taken off.... anywayz....
anybody has some info....
Old Jun 19, 2003 | 10:42 AM
salbaje's Avatar
get a distributor housing that lines up and swap out internals
lancerkid06
10
Mar 20, 2008 09:56 AM
racingcrx
Feb 5, 2006 01:00 PM
SiR_Injected
Nov 24, 2005 11:54 AM
mr_valentino20032000
Sep 28, 2004 07:28 PM
b17gsr
Jan 17, 2004 11:24 AM
