hondata clutch switch???
Ok i've already looked through the archives on how to solder the wires to the exsisting cruise control wires, but can some one show me a pic of how it looks and a pic using the actual hondata switch. Is there any way to use both switches??
Why would you want to? And where would you put the hondata switch if you kept the cruise control switch?
All the cruise control switch does is disable cruise control when you put in the clutch....and the only reason you'd put in the clutch while cruise is on is to slow down, and if you were slowing down you'd hit the brake very soon after, and the brake would disable the cruise control......
I ditched my cruise control switch with no problems, and love the 2-step
Brian
Brian
digital sol
Jul 27, 2006 05:15 PM
