Will 99-00 si coupe stock b-piping fit 96-00 hatch?
Old Jun 17, 2003 | 09:50 PM
Shorty C's Avatar
Default Will 99-00 si coupe stock b-piping fit 96-00 hatch?
just as topic says
Old Jun 17, 2003 | 09:53 PM
underrated99si's Avatar
Default Re: Will 99-00 si coupe stock b-piping fit 96-00 hatch? (sykol)
IF it has B series motor and header and cat the B pipe will fit no prob example a Hatch with a B16 and cat would be the same as the 99-00si or any other B series motor with the bottom portion of the header of a 99si so that placement would be in correct spot.
Old Jun 17, 2003 | 09:55 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: Will 99-00 si coupe stock b-piping fit 96-00 hatch? (underrated99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underrated99si &raquo;</TD></TR><TR><TD CLASS="quote">IF it has B series motor and header and cat the B pipe will fit no prob example a Hatch with a B16 and cat would be the same as the 99-00si or any other B series motor with the bottom portion of the header of a 99si so that placement would be in correct spot.</TD></TR></TABLE>i was pretty sure that the b-pipes were interchangeable
Old Jun 17, 2003 | 09:58 PM
Default Re: Will 99-00 si coupe stock b-piping fit 96-00 hatch? (CiRcUiTsi)
They are but on a HB like a DX with a stock motor the B pipe is longer cause the cat is in the header itself so the b pipe is about a 5 inches longer. It will work IM just saying for plug and play
jus f0 dekarayshunZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underrated99si &raquo;</TD></TR><TR><TD CLASS="quote">They are but on a HB like a DX with a stock motor the B pipe is longer cause the cat is in the header itself so the b pipe is about a 5 inches longer. It will work IM just saying for plug and play </TD></TR></TABLE>ahh i knew it...i was wondering why my buddy didnt have a cat
GSRkid123
Feb 28, 2008 04:10 AM
89civicdx
Sep 24, 2007 04:05 PM
crazyguy
Jun 14, 2007 07:52 AM
bOOsTiNSoHcVtEc
May 27, 2004 05:22 PM
