tips for replacing fuel pump
Old Jun 17, 2003 | 09:42 PM
brbHPR's Avatar
Default tips for replacing fuel pump
any of you guys have tips on taking out my fuel pump?
do i REALLY need to take out the whole fuel tank?
also, have any of you used one of those universal pumps that they sell at the auto parts stores
thanks
Old Jun 17, 2003 | 10:11 PM
Malgerus's Avatar
Default Re: tips for replacing fuel pump (brbHPR)
Get a Holley 190 lph, it's cheaper than stock and it flows a hella lot better. ( P# 12-917), ust be sure to get a strainer for your 88-91 application.
tips: try this site: http://www.sfu.ca/~ims/ (in the How to section...)
Any specific questions, IM me.
Old Jun 17, 2003 | 10:20 PM
tilt's Avatar
i made a quick write-up a long time ago:
https://honda-tech.com/zerothread?id=346111
1. disconnect battery
2. back seat area - remove the cover on the sending unit - 3 screws - this will give it slack - and unplug the wire harness
3. jack car up - put on jack stands
4. drain fuel if you dont want it to get everywhere - bolt located on bottom rear left corner of tank
5. remove splash shield cover to the left of the fuel tank - you will see fuel lines once it's off
6. use a jack to support the fuel tank
7. unscrew the 2 tank straps - just the rear side - deepsocket 12mm or open wrench
8. lower the tank - keep an eye on the wire at the rear of the tank so it doesnt snag - you should now be able to see the the fuel pump on the rear left side
9. there are 2 lines to the pump - remove one fuel line at the pump (dont lose the washers) and follow the metal fuel line to a rubber hose - remove the rubber hose
10. unbolt all the 10mm (might be 8mm) nuts - pull out the pump.
11. replace pump and strainer (self explanatory)
12. reverse order - done
90 ef
Dec 2, 2009 05:33 PM
hamizle
Aug 17, 2009 02:38 PM
KevronsEG
Jul 6, 2007 02:47 PM
JeDPhelps
Feb 5, 2006 05:41 PM
SpeedMonkeyRacing
Nov 29, 2002 06:08 AM
