Quick H22A power
a cai if your on a tight budget.
how much are you looking to spend would be appropiate to include with this question. best bang for the buck is subjective to price limitations in my book.
I recently bought an 01 Lude, if your goin NA the , intake,headers, exhaust is where to start.From there it's personal pref on whats next.Otherwise, turbo is the best bang for the buck that I can find.Can't wait to start on mine! I will also doing alot of susp mods to my car to get GREAT handling,LUV the corners!! What all do you have in mind and is $$ an object currently? $$ to do all we want is usually the issue. My $$$ trees keep dyin', tooo much watering I guess. Good luck.
There is no more cost-effective mod than nitrous. 60-70 whp for around $500 is a real bargain, especially by FI standards.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 »</TD></TR><TR><TD CLASS="quote">NOS. nah. im not into that much of a 'blowing the motor' risk.</TD></TR></TABLE>
If you're a little paranoid and worried about blowing the motor with nitrous, use the correct shot for your application and/or get either the Venom VCN -2000 kit (far more expensive though, more than twice the price). It monitors your a/f ratio and will cut itself off if you run lean, before you start blowing **** up.
Just be smart about using it and you have nothing to worry about. Check the plugs and check compression often. Only spray for ~10 sec's at a time and let it cool off for about 15 min's between runs. Use a WOT microswitch and get a RPM switch as a safety net. Nitrous has a bad rep b/c the little ricers that just bolt 'em on their cars and go w/ no knowledge on using it, then blow their motors a week later.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J01SH »</TD></TR><TR><TD CLASS="quote">It goes by lbs. it runs around $4 per lb. to refill a 10lb bottle
Take the red pill ............join the dark side.........Juice it.</TD></TR></TABLE>
Wow $4? That kinda sucks. I pay $3 per lb.
my opinion is if you have some hook-ups, buy a clutch and flywheel, or just the flywheels, but get the lightest flwheel you can buy, will easily take a second off almost any car. put a 9 lb one on my LS integra with i/h/e, and beat a awd talon turbo (stock) 3 times in a row in the 1/4
if not, get cam gears, unorthadox racing pullies, hondata gasket (call landspeed raceing and ask, they will tell you
, and tune the motor
other than that, internals or head work
, and tune the motorother than that, internals or head work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 »</TD></TR><TR><TD CLASS="quote">$500 budget... </TD></TR></TABLE>
Geez, start reading everything you can find. You're not going to get a solution for $500, especially since you've already shot down the obvious answers. You REALLY need to save some more money before starting in on this stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUCKO5 »</TD></TR><TR><TD CLASS="quote">my opinion is if you have some hook-ups, buy a clutch and flywheel, or just the flywheels, but get the lightest flwheel you can buy</TD></TR></TABLE>
If he's short on cash he'll definitely need a hook-up. Installation on a flywheel can cost as much/more than the part itself...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">if not, get cam gears ($140-ish), unorthodox racing pullies (full set of 3 {c/ps/alt}: $265), hondata gasket (call landspeed racing and ask, they will tell you) ($60; got mine from KS-Motorsport yesterday)</TD></TR></TABLE>
The 3 of those together are relatively cheap, but really won't net you much at the wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">and tune the motor</TD></TR></TABLE>
Kinda unclear here. Are you referring to the cam gears or fuel management or what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">other than that, internals or head work</TD></TR></TABLE>
Internals don't make hp, they prepare you for more hp, and head work is expensive; if it wasn't, I'd have that P&P TB, IM, and head by now.
Thanks for ideas.......Lol i can afford more than 500......i allready got aem intake, nology wires, and denso iridium plugs iwas just looking for what everyone thought was the best for the buck...Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus »</TD></TR><TR><TD CLASS="quote">lol...ya got nology wires and denso iridium's, but now you want to know what's the best bang for the buck....hehe, just a bit funny to me</TD></TR></TABLE>
That was soooo COLD dude.
I wanted some HotWires but they were too damned expensive...so I just got some Hot Wings instead. P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Final Flash »</TD></TR><TR><TD CLASS="quote">
I wanted some HotWires but they were too damned expensive...so I just got some Hot Wings instead. P </TD></TR></TABLE>
I don't think this guy knows much about bang for the buck. Look at all his Mugen crap
lol... J/p
Modified by PoweredByPrelude at 10:19 AM 6/19/2003
I wanted some HotWires but they were too damned expensive...so I just got some Hot Wings instead. P </TD></TR></TABLE>I don't think this guy knows much about bang for the buck. Look at all his Mugen crap
lol... J/pModified by PoweredByPrelude at 10:19 AM 6/19/2003
you should get nitrous but get a compression check and leakdown first. If its good then buy the kit then you have to as a precaution cause with any forced induction the more you do to it the better it is. Like upgrading your fuel ,timing,and yes i/h/e is better to for better flow so the engine can breathe then you have to learn how to drive with the nitrous on. Beware a 50 shot will have you like wow the power the first time i tired it i felt like super man but after i blew it upin the shot and didnt have enough fuel and leaned out . I felt like i got hit with a huge damn piece of kryptonite.
i think a clutch might be a good way to go to keep it simple. A friend of mine just got a new clutch for his GS-R and the car is pulling like crazy. of course driving his car is a work out, but chirping from 2 --> 3 is a completely foreign feeling to me being that i've always driven hondas
It's not "cheap" but it'll make a big difference. Also i would get a shorter gears but that's $$$ too...
I'm trying to keep my engine as close to stock as possible so outside of I/H/E i think transmission/suspension work would be my solution for making my lude even funner to drive.
It's not "cheap" but it'll make a big difference. Also i would get a shorter gears but that's $$$ too...I'm trying to keep my engine as close to stock as possible so outside of I/H/E i think transmission/suspension work would be my solution for making my lude even funner to drive.
