Summit Rpm Activator switch... No work.. HELP!!
Old Jun 17, 2003 | 08:14 PM
Sirex's Avatar
Default Summit Rpm Activator switch... No work.. HELP!!
well, its powered right because the red light comes on it.. the ground is fine else the red light wouldnt come on.. im using the 30 amp relay.. i have the vtec wire connected fine.. the rpm signal is the - on the distributor... i have the switches set at 2400 so it can activate at 4800... i have all the power and grounds fine.. and relay but it seems like its not picking up the signal from the distributor... my vtec does work cuz i had an MSD that worked and a vafc that worked.. and i threw a direct 12v to the vtec selenoid and it works... what could be wrong?
Old Jun 18, 2003 | 03:10 AM
Sirex's Avatar
Default Re: Summit Rpm Activator switch... No work.. HELP!! (Sirex)
ttt
Old Jun 18, 2003 | 10:26 AM
Sirex's Avatar
bump
Old Jun 18, 2003 | 10:32 AM
USDM 4G VTEC's Avatar
dont say that its wired right if its not turnin ur solenoid on
check all the wirin again
maybe u made a booboo somewhere
check for this
MSD RPM A/S
red to switched 12V
white to the neg terminal of ur dizzy coil
black to GND
yellow to 85 on relay
then on the realy
87 to VTEC solenoid
86 to red on MSD
85 to yellow on MSD
30 to 12V+
Old Jun 18, 2003 | 09:24 PM
Sirex's Avatar
Default Re: Summit Rpm Activator switch... No work.. HELP!! (USDM 4G VTEC)
its wired exactly like that..
Old Jun 19, 2003 | 02:40 PM
Sirex's Avatar
bump it up
Old Jun 19, 2003 | 09:48 PM
Sirex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">dont say that its wired right if its not turnin ur solenoid on
check for this
MSD RPM A/S
red to switched 12V
black to GND
then on the realy
87 to VTEC solenoid
86 to red on MSD
85 to yellow on MSD
30 to 12V+</TD></TR></TABLE>
ehh isnt it 86 yellow 85 red
Old Jun 20, 2003 | 05:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sirex &raquo;</TD></TR><TR><TD CLASS="quote">
ehh isnt it 86 yellow 85 red</TD></TR></TABLE>
nope
m,aybe thats why isnt working for you
i had it just like i wrote it and it worked fine for ever
Old Jun 20, 2003 | 06:30 AM
Swift's Avatar
get a volt/ohm meter hooked up to the activator, have a freind rev the engine and see if you can detect a signal.
ryanbartholomew85
Mar 11, 2005 12:52 PM
spettinger
Nov 18, 2004 01:45 PM
racingant
Jan 11, 2004 05:15 PM
0554
Sep 8, 2003 09:19 AM
7rrivera7
Oct 15, 2002 11:44 PM
