Question on fuel pressure regulators
Old Jun 17, 2003 | 06:10 PM
Joon525's Avatar
Default Question on fuel pressure regulators
You know how if you remove the vacuum line going from the regulator to the intake manifold it's supposed to simulate wide open throttle........why is this???
I thought that by removing this line the "valve" in the regulator would not pull up. I figured that when the car is at WOT the vacuum would be the greatest and hence pull up the valve the most....yet when the line is detached there is no vacuum and thus wouldn't the valve in the regulator be closed?
I'm probably missing something very basic here (it's been a long day).
Old Jun 17, 2003 | 07:47 PM
altoid's Avatar
Default Re: Question on fuel pressure regulators (Joon525)
at WOT there is no vacuum at all whatsoever...the air is going in as fast as the engine can take it. So if you take off the hose you have 100% airflow. much like having the butterfly in the TB removed.
Old Jun 17, 2003 | 08:13 PM
Joon525's Avatar
Default Re: Question on fuel pressure regulators (altoid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by altoid &raquo;</TD></TR><TR><TD CLASS="quote">at WOT there is no vacuum at all whatsoever...the air is going in as fast as the engine can take it. So if you take off the hose you have 100% airflow. much like having the butterfly in the TB removed.</TD></TR></TABLE>
Ah OK I get it now. So when there's no vacuum that valve in the regulator will try to close thus diminishing the opening that allows fuel to flow and thus raising pressure.....much like placing your finger over the end of a garden hose.
Munkiep
Nov 8, 2011 05:30 PM
likwidchz
Aug 25, 2008 09:48 PM
polishedturd
54
Jun 5, 2008 02:00 PM
1.8
Jan 5, 2005 12:20 PM
93H22ACX
Feb 9, 2003 03:37 PM
