What can i do to make a b16a2 really fast?
Old Jul 22, 2001 | 04:02 PM
LiLxKiMcHeE's Avatar
New User
Default What can i do to make a b16a2 really fast?
What can i do to make a b16a2 really fast? Is it possible to put on a Civic Type R head (b16b) or a GSR head (b18c1) on a b16a2 block? If it is possible how much faster would it be? What if i left the b16a2 alone but i had a ITR ECU. Wouldnt that increase my HP and make me redline at a higher RPM? Or am i just smokin crack and i dont know what im talkin about.
Old Jul 22, 2001 | 04:53 PM
TheShad0w's Avatar
Default Re: What can i do to make a b16a2 really fast? (LiLxKiMcHeE)
the only real way to make a b16 really fast is to turbo it, there are lots of things you can do to increase its efficientcy tho such as weight reduction, cam gear tuning, and mild set of cams, underdrive pulleys, I/H/E, clutch, short gear ratios...
Old Jul 22, 2001 | 08:57 PM
FIVE.ONE.ZERO's Avatar
New User
Default Re: What can i do to make a b16a2 really fast? (TheShad0w)
ive seen fully a built b16 with t3t4 turbo boosting 12psi runing mid 13s (thats a whole lotta money) other b16 stock motor 80 shot single fogger also hitting mid 13s(low budget) its up to you
Old Jul 22, 2001 | 09:28 PM
TheShad0w's Avatar
Default Re: What can i do to make a b16a2 really fast? (FIVE.ONE.ZERO)
um, i hope they guy running 13's w/ that much boost was in 5000+ altitude, or had a broken turbo, there are Si's pulling solid mid to high 13's on 8 pounds on stock blocks....
justinboost
Dec 24, 2012 06:41 AM
civdawg
Nov 9, 2011 03:23 PM
EM199dcs
Jan 10, 2006 03:57 PM
NA JDM GSR
Feb 14, 2005 05:55 PM
wicked2night
Nov 14, 2004 12:17 PM
