for sale lots of stuff need to sell asap.
Old Jun 17, 2003 | 03:17 PM
BstnLsVtec's Avatar
Default for sale lots of stuff need to sell asap.
MSD Digital 6 plus ignition. $250 O.B.O
C&R Radiator for 92-2000 Civic $400
Civic Type R headlights 99-00 civic $450
Custom Turbo Kit for any B-Series Civic or Integra, (this kit Includes) Drag Manifold, Tial 35mm wastegate, Drag Downpipe w/ O2 bung and flexpipe, Garret T3/T4 57 trim Turbo, SFP Intercooler piping, Xs Engineering Sylvia Intercooler, Greddy Type S B.O.V, Synapse Missing link, all couplings, fittings, clamps, and oil lines
kit has 1,000 miles on it with a brand new turbo
$2,800 O.B.O
Fully built ls vtec long block (built for turbo) includes - micropolished ls crank manley rods, je 9:1 pistons ,all new gaskets and seals, tapped oil pan for turbo, brand new water pump and oil pump, engine bored .20 over, je high tension rings, arp head studs, cometic 1.2mm head gasket, block decked, b16a2 head, milled head, port and polished head, ferrea valves, skunk2 valve springs and titanium retainers, all new seals and gaskets, crower turbo cams, aem cam gears, vtec solenoid, distributor, msd wires, msd distributor cap, msd blaster ss coil, skunk2 intake manifold, rc 440cc injectors, aem fuel rail engine also comes with new rod and main bearings. engine very clean. motor has 1000 miles on it with new bearings, gaskets, seals and rings. this engine made 350hp on 10psi and is capable of handling up to 18psi safely.
$5,700 O.B.O
ACT XTSS Clutch kit for any hydro B-series motor
$425 O.B.O
Cusco Oil catch can
$100 O.B.O
Custom 3 inch exhaust for 96-00 civic $500 O.B.O
Mazda 20b in tank fuel pump $350 O.B.O
Autometer carbon fiber boost and oil pressure gauges comes with A-Pillar pod $60
Greddy Profec E-01 Boost controller $500 O.B.O
OBD 1 P72 GSR Ecu - $275 O.B.O
Skunk2 OBD 2 to OBD 1 Jumper Harness - $200 O.B.O
Or i will sell everything listed above together for $11,500.00. i also have the following items for sale.
JE stock compression pistons for any B series motor (includes wrist pins but no rings.) $350 O.B.O
Crower Billet rods for B16 $580 O.B.O
MSD SCI Ignition box w/ blaster ss coil $100 O.B.O
Turbonetics T3/T4 hybrid turbo, this is a 50 trim with 500 miles on it. $600 O.B.O
If you are interested in anything please call me at 513-615-2191 or email me at jwkperformance@aol.com thanks.
Old Jun 17, 2003 | 04:50 PM
BstnLsVtec's Avatar
Default Re: for sale lots of stuff need to sell asap. (BstnLsVtec)
come on i know there is someone on this site that needs at least some of this stuff i will work on the prices if need be
Old Jun 17, 2003 | 07:04 PM
underpressure02's Avatar
what color is the C&R any pics?
1bar_ek
Jun 15, 2008 06:00 AM
RyanAutry
Feb 3, 2003 12:15 PM
RyanAutry
Nov 22, 2002 05:55 PM
