Just bought a JDM 23mm... What am I missing to put it on...
Ok, I know which parts I need to order... but I am not 100% sure which part is which... Oh, it's going on a 93 Civic CX
Here's what I got... GSR rear LCAS and this..
I know I'll need a mounting kit (I'll prolly go BSQ)...
Here's the list of what I need, but I want to know what exactly do I have already (in the pictures above)
1.) 52300-ST7-Z01 rear swaybar ($71.77) - I got this (actually I got the JDM 23mm one so not really)
2.) 52315-ST7-Z01 swaybar bushing ($4.49) (2 needed) - I'm guessing I have these?
3.) 52308-SS0-000 bushing bracket ($6.09) (2 needed) - Is this the D Bushing bracket? If so, I'll need these...
4.) 52316-ST7-Z00 endlink bushing ($1.76) (2 needed) - I'm also guessing I have this since the endlinks I have look complete...
5.) 52312-ST7-Z00 endlink bushing collar ($5.00) (4 needed) – Actually I only need 2, but either way, I already got these right?
6.) 90175-ST7-Z00 bolt (8x35) ($2.47) (2 needed) - Definitely will need these...
7.) 94050-08080 flange nut (8mm) ($0.08) (2 needed) - And I'll need these...
So I THINK I just need to buy the BSQ mounting kit (or beaks if I feel bling bling) and (2) 52308-SS0-000 bushing brackets, (2) 90175-ST7-Z00 bolts (8x35), and (2) 94050-08080 flange nuts (8mm)...
Right? Am I missing anything?
UPDATE - Just noticed something...... I am also missing 4 bolts to bolt on the D-brackets.... I know the Beaks kit comes with these bolts...... does the bsq kit come with them? If not, what kind of bolts/nuts are needed for the d-brackets?
Modified by Tr0LL at 12:00 AM 6/18/2003
Hey man ur gonna need lower control arms that have the bolt holes for the rear sway bar thats about it i got a set here
doh! damn attention span...paid more attention to the one line reply than I did to the huge original post
just noticed something...... I am also missing 4 bolts to bolt on the D-brackets.... I know the Beaks kit comes with these bolts...... does the bsq kit come with them? If not, what kind of bolts/nuts are needed for the d-brackets?
bump! c'mon guys, what do i do for those 4 bolts? someone with an EG must have went through the buying process... I want to order ASAP so I can put this bar on...
Modified by Tr0LL at 11:56 PM 6/17/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damon »</TD></TR><TR><TD CLASS="quote">BSQ is ok, Beaks is MUCH better.</TD></TR></TABLE>
It actually should be.... BSQ is GREAT... Beaks is better...
Probably, but for $45 more.... I'll pass
. Hell my friend is actually giving me his BSQ kit, so beaks would be $65 more... Both do the same thing... Neither will have any problems...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tr0LL »</TD></TR><TR><TD CLASS="quote">bump! c'mon guys, what do i do for those 4 bolts? someone with an EG must have went through the buying process... I want to order ASAP so I can put this bar on...
Modified by Tr0LL at 11:56 PM 6/17/2003</TD></TR></TABLE>
The 2 bolts and flange nuts that you order from Honda will be used on the bottom of that D-bracket (goes through the spacer incl. w/ the BSQ kit). The top bolt is just one of your stock bolts, unless you don't have a swaybar at all right now. I know it's an 8mm thread bolt but I don't know the thread pitch or the length.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tr0LL »</TD></TR><TR><TD CLASS="quote">bump! c'mon guys, what do i do for those 4 bolts? </TD></TR></TABLE>
home depot.
you need to drill your subframe anyway , just get grade 10 nuts/bolts.
home depot.
I need to know the same things- I have a '92 CX (no factory bars)-
Any idea of bolt size needed for attaching the sway bar bushing brackets to the subframe? Also what bolts/bushings are necessary for attaching the sway bar to the endlinks and the endlinks to the LCA (I have Type R LCAs+endlinks)?
Thanks
Ben
Thanks
Ben
Tr0LL
Jun 21, 2003 09:00 AM
ryanhook
May 8, 2003 11:58 AM
