Need Integra rear lower arm diagram
I have a stripped bolt where the rear sway bar connects to the control arm. I was looking at acuraautomotiveparts.org to find the part but the diagram is missing.
EDIT: The diagram is for "Rear lower arm"
Anyone have it or know where I can find it?
I already searched btw.
Kevin...which one is it..I have some stock sway bar bolts just laying around in the garage. I might have the one you need. If I'm thinking right it's the little bracket that sits above the LCA right?
yea that's the one, you have a PM
This is the picture of the left side of the sway bar with the bracket still on
Here is the bracket close up...that hole is where my bolt broke off from
Any clues?
Here is what is left of the bolt btw:
Modified by lustedp at 4:58 PM 6/17/2003
Any clues?
Kevin...I looked last night and I have almost every sway bar bolt but that one....figures. Your best bet might be to just get it from Acura. That bolt can't be more than a couple of dollars.
Pay or you dont play.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lustedp »</TD></TR><TR><TD CLASS="quote">the bushing is 8 bucks, the bolt is 1.32
I just got the parts from Len (baranco acura)
Here is the picture of the rear lower arm:
(add orig.jpg for larger)
The part is #9...a rubber bushing with a metal tubular insert in it where the bolt goes through. How do I get that into #6 the metal bracket?
EDIT: You can also see the bushing in the bracket in the earlier pictures.
(add orig.jpg for larger)The part is #9...a rubber bushing with a metal tubular insert in it where the bolt goes through. How do I get that into #6 the metal bracket?
DerangedEG
May 14, 2004 11:48 AM
