What's that noise?
Old Jun 17, 2003 | 08:26 AM
STOLEN - ITR 98-0652's Avatar
Default What's that noise?
I get a "click" at low speeds. It happens when I engage/disengage the clutch, but not exclusively. It also happens when I go off throttle at higher (5500) rpms.
I don't suspect release bearing (12000 miles old) since it is not exclusively related to the clutch. Also, I only hear it in N->1 and 1->2 shifts. Even at elevated rpms, I don't hear it on the 2->3 shift.
I checked CVJs on that side, and there's no apparent signs of boot damage. It has that kind of click to it, but it only makes the noise at higher torque situations (on or off).
Any thoughts? ((please please please don't be a tranny problem with the shift fork or somesuch)).
Thanks in advance.
Old Jun 17, 2003 | 09:33 AM
Haunt's Avatar
Default Re: What's that noise? (ITR 98-0652)
This was covered just recently...here is a few links for you...
https://honda-tech.com/zerothread?id=535164
https://honda-tech.com/zerothread?id=440637 -- This one is good
Edit: Here is another on the first page: https://honda-tech.com/zerothread?id=537577
Old Jun 17, 2003 | 01:18 PM
kepani's Avatar
i have the exact same problem. i'm taking my car in this friday to have it looked at and most likely to be fixed under warranty.
Old Jun 17, 2003 | 01:28 PM
DutchITR1689's Avatar
Check both front spindle nuts (hub). It could be loose....
zach1288
15
Dec 2, 2008 04:49 AM
actionfigure
Jan 14, 2007 05:10 AM
Bob98EXCoupe
May 10, 2005 05:18 PM
CDN Yellow ITR
Feb 10, 2005 02:38 PM
95 silintegra
Oct 3, 2003 05:46 AM
