stock exhaust leaking
my ls has the stock exhaust still ..theres seems to be an exhaust leak right at the begining of the resonator...is there a problem with me just removing the resonator on the stock exhaust...till money comes around for a new exhaust..im sure the leak can be fixed with a lil welding but what about cutting the resonator out and welding a piece of pipe....thanks for comments..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it »</TD></TR><TR><TD CLASS="quote">is it a good idea - bad idea - dont make a difference other than being a lil louder</TD></TR></TABLE>
this is the question i need answered or help with...
yes its very annoying...and u feel the difference in the car with the exhaust leak...
Without the resonator it'll definitely be louder. The muffler works with the resonator in order to cancell out sound wave pulses. Though, it may flow better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg-your-it »</TD></TR><TR><TD CLASS="quote">thank you thats the kinda responses i was looking for...any more?
louder, not n1 loud right...</TD></TR></TABLE>
Well that I don't know. Probably sound like a Pep-Boys free-flow muffler, yuck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain »</TD></TR><TR><TD CLASS="quote">try some exhaust wrap or get it patched till you can afford an exhaust. DO NOT remove your resonator </TD></TR></TABLE>
can u please explain why i should NOT remove the resonator...?
i will be going today on my lunch hour to fix this...
the exhaust wrap wont work..its leaking from the resonator welds...but i dont want to fix the resonator i want to remove it..yes i know it will be a lil louder but are there any loses from me removing it...
Modified by teg-your-it at 8:55 AM 6/18/2003
Deff no loses from removing the resonator. if anything, you will get gains.
Modified by teg-your-it at 8:55 AM 6/18/2003</TD></TR></TABLE>
thats what im thinking...a lil better flow cant hurt...its still the stock exhaust just minus the resonator...i just hope it dont sound shitty afterwards...any more comments? TIA
ok its done...removed the resonator but also had to put new piping from the cat to the muffler...**** was all rusted i didnt even want to bother putting that pipe in but from the looks of the rust there was no tellng how long it was gonna hold up...40 bucks though wasnt bad...
sounds the same as before nothing different till up past 5k rpm then it starts to buzz...its not bad though its livable with for now...as far as flow...butt dyno said it pulling like it should...
