Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
1995 Prelude for Autox: Any caster & camber recommendations?
Old 04-29-2018, 09:49 AM
moto44's Avatar
Default 1995 Prelude for Autox: Any caster & camber recommendations?
What should I be shooting for on my caster camber 95 prelude. 7in bfg comp tires .
Old 04-30-2018, 05:44 PM
boxedfox's Avatar
Default re: 1995 Prelude for Autox: Any caster & camber recommendations?
As much caster as you can get up front. Camber wise, see if you can get -2.5 deg Front, -2 deg Rear.
Old 05-03-2018, 06:30 AM
moto44's Avatar
I have -2.5 camber in front now caster is also +2.5 . But if I swap the upper control arns put the left on the rt I can get the caster up to +7 but it puts the ball joint in a bind.
Old 05-03-2018, 06:49 AM
boxedfox's Avatar
If you can get 2.5 deg positive caster, you're actually doing pretty well. A lot of track driven cars don't have as much as you do. I wouldn't swap the control arms because as you said, that introduces a myriad of other issues including suspension bind. From there on I'd recommend relying on your pyrometer to get everything fine tuned. These cars tolerate a fair bit of front and rear toe out in an auto-x environment, so if you're having trouble the car to rotate don't be afraid to point the wheels out 1/16" or so.
CivicSiRacer
27
04-14-2015 05:26 AM
rasmussen00
01-21-2011 04:26 PM
wannaBjdmca6
Suspension & Brakes
26
01-16-2011 08:24 PM
vinuneuro
Suspension & Brakes
01-26-2007 11:43 AM
Quick Reply: 1995 Prelude for Autox: Any caster & camber recommendations?
