blue smoke and clutch ?
Old Jun 16, 2003 | 10:03 PM
tgod1020's Avatar
Default blue smoke and clutch ?
my 91 civic lx throws out alot of blue smoke and the engine ticks i am geting a b16 by the end of summer should just put some of that blue smoke be gone stuff and my clutch pedal is hard and i tryed ajusting it but does not really help if i get a new clutch will it be softer
thanks
Old Jun 16, 2003 | 11:11 PM
JonGP4's Avatar
Default Re: blue smoke and clutch ? (tgod1020)
if i remember correctly blue smoke means your rings are going out. which is not good, eventually you will loose compression and the car will not run. as for ur clutch, the stiffness is determined mostly by the springs on your pressure plate, so yeah a new OEM clutch would take care of that.
your engine is tickings? umm could be ur valves? need more info on that.
Old Jun 16, 2003 | 11:23 PM
boarderdudeh's Avatar
Default Re: blue smoke and clutch ? (JonGP4)
can you say...smoke em boys??
cambopheonix56
Nov 25, 2004 04:52 AM
del soler
Oct 3, 2004 06:12 AM
kevinoneill
Aug 14, 2004 09:45 PM
EG2 SiR
Jun 24, 2004 05:10 AM
