Rubbing with 225/45 16 P Zeros on 16*7.5 wheels with 45mm offset?
Old Jul 22, 2001 | 06:30 AM
MikeD's Avatar
New User
Default Rubbing with 225/45 16 P Zeros on 16*7.5 wheels with 45mm offset?
225/45 16 P Zeros on 16*7.5 wheels with 45mm offset? Anyone have experience with this exact combination? I am thinking of moving to a wider tire, possibly just in front but I am concerned about potential rubbing. Thanks in advance...
Old Jul 23, 2001 | 01:28 PM
MikeD's Avatar
New User
Default Re: Rubbing with 225/45 16 P Zeros on 16*7.5 wheels with 45mm offset? (MikeD)
ttt
Old Jul 23, 2001 | 01:52 PM
yoshi234's Avatar
I shoot brides
225 might be okay in front, but it will *not* fit in the rear w/ +45mm offset. It's a tight sqeeze w/ 50mm offset wheels. Bring the wheels out w/ the 45 will cause the wheels to rub the rear fenders. Of course, you can alway "roll" your fenders to make some room.
-y
Old Jul 23, 2001 | 02:34 PM
Jason's Avatar
Default Re: Rubbing with 225/45 16 P Zeros on 16*7.5 wheels with 45mm offset? (yoshi234)
Ok, I have a set of spoons 16 x 7 (+45 Offset) and I just put on a set of 215 45-16's and they just BARELY fit, and I also shaved about half of the width of the lip of the fender (sorry about construction of sentence..didn't know how else to word it)
I don't think it will fit.
Old Jul 23, 2001 | 02:46 PM
norice's Avatar
Default Re: Rubbing with 225/45 16 P Zeros on 16*7.5 wheels with 45mm offset? (typer98)
I have 225/45 16 P Zeros on 16*7 wheels with 50mm offset. I am also 3/4" lower than stock. A little rubbing when wheel is at full lock but it is only an issue when parking.
I don't think you will make it with a 45mm offset.
Old Jul 23, 2001 | 04:45 PM
MikeD's Avatar
New User
typer98: did you trim just the back ones or the front too?
norice: did you trim the inside of the fender at all?
I am thinking of using 225/45 16 in front and 205/50 16 in the rear so I am really only concerned about the front.
Old Jul 23, 2001 | 04:48 PM
norice's Avatar
I did not trim at all. Rubbing only happens at full lock so it is not an issue - if you are at full lock at greater than 5mph, you have other problems.
Old Jul 23, 2001 | 04:53 PM
2fcknfst's Avatar
Default Re: Rubbing with 225/45 16 P Zeros on 16*7.5 wheels with 45mm offset? (norice)
Once again...
I run a set of 16x8 inch wheels, 225/40 16 rubber. In order to make the works fit, I spent countless hours screwing around with my lathe, a tape measure and a great deal of patience.
I utilize a 3mm spacer; this allows this wheel to fit with no clearance issues.
You may consider taking your wheels to a compotent machinist and having 2mm shaved from the hub. This will also correct your fitiment problem without having to use a spacer.
Old Jul 23, 2001 | 05:05 PM
Jason's Avatar
just the back fenders
Old Jul 24, 2001 | 08:31 AM
Boba-Fett's Avatar
New User
Default Re: Rubbing with 225/45 16 P Zeros on 16*7.5 wheels with 45mm offset? (George Knighton)
yes they do.
Old Jul 24, 2001 | 09:05 AM
Black R's Avatar
25 Year Member
Default Re: Rubbing with 225/45 16 P Zeros on 16*7.5 wheels with 45mm offset? (2fcknfst)
Once again...
Just out of curiosity, what rubber are you running right now? Impressions, suggestions to those of us shopping for tires for 16x8 wheels?
Thanks.
Manga_Spawn
Honda Fit
Jan 8, 2009 09:51 PM
HS2G
Jun 16, 2007 11:50 PM
portaman03
Honda Civic (2001 - 2005)
Apr 11, 2007 09:31 PM
willyboyK20
Jun 25, 2002 10:42 AM
ochdog
Jun 5, 2002 05:07 PM
