zc ?
Ive already bought a zc but from what I have researched there are 2 differant ones? there really isnt much claification on this...ie..zc does not work on the search engine here..so I ended up goin through 186 crx swap articles..great time...any how is there any real differances in the swap such as bell housings..wiring ect..from what ive read since i have a 88 si its pretty much a simple swap..I have done a few b16 swaps and there not too complicated with the right tools and all the parts needed so I want this swap to go as smoothly
What 4th said and also the black top dohc vs the brown top dohc, if you have a dohc you better hope you got the black top. Give us some info on what you got and we'll let you know what to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cd1fidy »</TD></TR><TR><TD CLASS="quote">so the black top fits in the second gen or better</TD></TR></TABLE>
yes. i have a black top zc (well I'm assuming it was a black top- when I got it the valve cover was a polished valve cover- dirty as hell, but it was silver & not black
next thought are ls rods a direct swap...I have seen a few posts on it but it wasn't really a deffinate yes or no...from what I have been reading the rods are the main weak link in the enginge..and with a strong set of apr studs and rods with some good quality time on the dyno I should be able to run a little extra boost and still have some dependability
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cd1fidy »</TD></TR><TR><TD CLASS="quote">next thought are ls rods a direct swap...I have seen a few posts on it but it wasn't really a deffinate yes or no...from what I have been reading the rods are the main weak link in the enginge..and with a strong set of apr studs and rods with some good quality time on the dyno I should be able to run a little extra boost and still have some dependability
no
</TD></TR></TABLE>no
you need bushings and the bottom ends have to be machined to fit the stock honda crank.
but im seling a set if you want some: https://honda-tech.com/zerothread?id=516061
SIred91
30
Aug 17, 2006 07:35 PM
