lsd question
anything i need to know about lsd before i get it. I am getting a 97 jdm type r lsd. Does the ring gear fit. do i need to know anything else i need to get. this will go into my 95 ls integra.
AFAIK, the OE Honda B18/B16 LSDs do not fit into the B18B trannys. You might do a search in the ITR forum, I remember people asking about this before over there.
ITR LSD will fit in the B18B tranny, but you have to change to the ITR/GSR ring gear, and I'm not 100% on this, but I think your LS tranny has a 4.266 final drive, and if thats the case, you have to change that as well. The USDM ITR/GSR has a 4.4 final drive. Ring gear is larger innner diameter on the ITR/GSR.
If you get beyond the ring gear/final drive problems, then there's a bit of grinding to do to the inside of the case to clear the larger diameter stuff as well.
Not to mention, if you change to a different ring gear, you have to change the countershaft.
If the stock ring gear works with the LSD, then use it, otherwise, you'll almost need the whole tranny.
shamoo
Mar 15, 2002 06:33 PM
