AEM wideband o2 sensor? Have you seen this yet?
Old Jun 16, 2003 | 07:37 PM
Black R's Avatar
25 Year Member
Default AEM wideband o2 sensor? Have you seen this yet?
http://www.ks-motorsports.com/...93651
Old Jun 16, 2003 | 07:55 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
i didnt know they had already come out.
Old Jun 16, 2003 | 08:36 PM
cheezthis's Avatar
Default Re: (Rguy)
Hmm...that's new to me. I've always known of people using the old Civic VX wideband.
EDIT: on me
Old Jun 17, 2003 | 03:44 AM
Asahi's Avatar
Default Re: (cheezthis)
Looks like a good setup Kenny. I sent an email about it to the Techedge email list to see what weaknesses they might pick on. At this point as long as you are running OBD1 a single channel system with sensor is cheap!
I have a techedge system but this looks to be worth considering.
Old Jun 17, 2003 | 04:01 AM
Asahi's Avatar
Default Re: AEM wideband o2 sensor? Have you seen this yet? (Black R)
Here is 2 questions.
1) Can it be used away from the AEM EMS?
2) How can you display the A/F ratio?
Old Jun 17, 2003 | 04:22 AM
J2turbo21's Avatar
Default Re: AEM wideband o2 sensor? Have you seen this yet? (Asahi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi &raquo;</TD></TR><TR><TD CLASS="quote">Here is 2 questions.
2) How can you display the A/F ratio?</TD></TR></TABLE>
What he said.
Old Jun 17, 2003 | 04:25 AM
Asahi's Avatar
Default Re: AEM wideband o2 sensor? Have you seen this yet? (J2turbo21)
Ok, The designer of the Techedge WBO2 emailed the list back and said that it lacks the display and that thenew v2.0 Techedge has a little more datalogging capability but that it looks to be a good unit and he would look into it in more detail. He also said they may build a display for the unit. . .
Sounds like at this point there is no visual display for the unit but short of that it is a good design. It uses the boasch (NOT Honda) wideband sensor which means a sensor will cost $30-$50 instead of $225+ (Honda)
Trey
Old Jun 17, 2003 | 04:42 AM
RTW DC2R's Avatar
I was reading about this on the aem site, then I saw the price on KS motorsports and was like
Old Jun 20, 2003 | 10:35 AM
mskibbz-T's Avatar
Yes, it can be used away from the EMS. It can output either 0-1 volts(to work with stock ECUs) or 0-5 volts for engine management setups(Hondata, EMS, etc..) Currently, the only way to display A/F is in your EMS, Hondata, etc... AEM says that they will have a gauge on the market within a couple of months to be used in conjunction with the AEM WBO2 setup. You can also get an Autometer or some other gauge recalibrated for the AEM WBO2 to use in the meanwhile or permanently... Bosch sensors are easy to find and are CHEAP, whereas the NKT sensors are getting ridiculously hard to find and prices are nuts If you are running the AEM EMS, it will require no calibration for the EMS to read it perfectly, on other systems you would go through the same process as with the FJO, TechEdge, etc.. in order to calibrate the system to accurately read the output voltages. It is a bad *** setup at a bad *** price, if I knew this was coming out I would not have chunked out $750 on my FJO setup
Old Jun 25, 2003 | 05:53 PM
Ryan C's Avatar
Default Re: AEM wideband o2 sensor? Have you seen this yet? (mskibbz-T)
could it work with e-manage?
Old Jun 25, 2003 | 05:59 PM
Asahi's Avatar
Default Re: AEM wideband o2 sensor? Have you seen this yet? (Ryan C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote">could it work with e-manage?
What do you mean work with e-manage? E-manage didn't sound liek anymore than a Greddy VAFC. DOes it have Autotune and voltage inputs for datalogging?
Old Jun 26, 2003 | 01:15 PM
mskibbz-T's Avatar
What do you mean work with e-manage? E-manage didn't sound liek anymore than a Greddy VAFC. DOes it have Autotune and voltage inputs for datalogging?</TD></TR></TABLE>
You CAN run the AEM WBO2 in 0-1V range in order to use it with your stock ECU... I don't know if you would have any real reason to run it to the EManange though, I doubt it can do anything with it.
Old Jun 27, 2003 | 04:40 AM
Asahi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mskibbz-T &raquo;</TD></TR><TR><TD CLASS="quote">
You CAN run the AEM WBO2 in 0-1V range in order to use it with your stock ECU... I don't know if you would have any real reason to run it to the EManange though, I doubt it can do anything with it.</TD></TR></TABLE>
There are lots of Widebands now running 0-1v (Narrowband output) but what si the poiint of doing that with an e-manage or even a hondata or Power FC with Datalogit? Seems like you woudl want to use the AEM and the others in their 0-5v output form.
Trey
Old Jun 27, 2003 | 09:01 AM
mskibbz-T's Avatar
Trey</TD></TR></TABLE>
It's just more resolution at 0-5V... it still gives accurate readings at 0-1V
11psiTurboSI
Sep 26, 2006 09:53 PM
11psiTurboSI
May 24, 2005 02:22 PM
vtecman
Feb 7, 2005 12:02 PM
93TurboSi
Jul 13, 2004 12:14 PM
wade
Jul 23, 2003 06:04 PM
