something is leaking
I'm still having more problems with my car. When I drive the car it makes a humming and thumping sound that gets louder poportionally to how fast I go. It also gets louder if I turn. I thought it might be my brakes, so i jacked the car, took of the front wheels and brakes and stepped on the gas - same noise. I noticed some fresh fluid on the ground where I had just parked it, so I put some cardboard to find where the link is coming from. Looks like its coming from tranny.
Also, WTF is all that orange stuff on the tranny? Is is supposed to be sealant or something? All i need now is to have to replace the tranny; i just spent a fortune replacing my engine
I'm thinking about taking it to another shop since my current one can't figure it out. Anyone know of any good shops in NJ?
WTF? That orange stuff is strange as hell and should not be there.
Looks like you are leaking tranny fluid. But the pictures are too big and angle isn't very good.
Sounds like an axle seal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">WTF? That orange stuff is strange as hell and should not be there.
Sounds like an axle seal.</TD></TR></TABLE>
yeah, and wtf is that orange ****?!?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97hb »</TD></TR><TR><TD CLASS="quote">Looks like someone used the orange stuff for a quick fix
thats probly what it is.
</TD></TR></TABLE>thats probly what it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonBlackEJ1 »</TD></TR><TR><TD CLASS="quote">
thats probly what it is.</TD></TR></TABLE>
ya. that **** needs to go.
yeah take that orange stuff off.. if you want to seal it.. try chiseling the transmission casing together ive done it in small leaky cases and it sealed it up...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miataguy »</TD></TR><TR><TD CLASS="quote">All the suspension components on the right side are extremely greased up. Could it just be an axle seal? How hard it it to replace?</TD></TR></TABLE>
Axle seals are very easy to replace. It's just a gasket that seals the oil inside the tranny casing with the axle inputs.
They run about $3 I believe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miataguy »</TD></TR><TR><TD CLASS="quote">would this be the correct part?</TD></TR></TABLE>
Damn you're quick. That would be the correct part if it is for your application.
actually, the tranny is supposed to be a GSR, so this would probably be better. Then again all the suspension is aftermarket and is getting on my nerves. I'll probably go back to the junk and get the stock axles, control arms, etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">Ya, who ever did that is one ghetto *** mechanic.</TD></TR></TABLE>
Bigtime...
Bigtime...
the orange shyt looks like some orange hondabond (stuff used to seal) j/p
but other wise i dont know what it could be...take it somewhere and they would prob give you a estimate for under $15 bucks just make sure they dont try to **** you over hope you fix it man good luck
Before you purchase anything, however. Make sure the source of the oil leak is where the axle input is.
It COULD be where that ghetto orange **** is and the gear casing not sealing with the bell housing properly.
Clean everything up and see where the source of the leak is.
PreyStayShun
May 8, 2011 10:03 AM
sigNAL_fiRE
Oct 3, 2005 11:10 AM
