Water pump replacement?
Old Jun 16, 2003 | 04:42 PM
parasonic's Avatar
Default Water pump replacement?
I remember that the water pump is a part that can wear out. A lot of friends have ended up replacing theirs... I have a 99EX; how many miles should I go before I replace it, or should I replace it at all?
Also.. do I need any special tools to replace a timing belt? I have about 10k miles left on it, but I look into maintenance early.
Old Jun 16, 2003 | 04:57 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Water pump replacement? (parasonic)
do the water pump when you do the t-belt.
No special tools for the belt, just a strong enough breaker to get the crank pulley bolt off
Old Jun 16, 2003 | 05:30 PM
parasonic's Avatar
Default Re: Water pump replacement? (Emerika)
Does this balancer belt ever need replacing?
Also... where do you recommend I get a new timing belt and water pump?
Thanks!
Old Jun 16, 2003 | 06:24 PM
zigs's Avatar
[QUOTE=Also... where do you recommend I get a new timing belt and water pump?
Thanks![/QUOTE]
Honda or Acura dealership OEM
Old Jun 16, 2003 | 06:26 PM
N~FaMouSKhMerBoi's Avatar
Default Re: Water pump replacement? (zigs)
do you guys also recommend lettin the dealer install it ? and how much did it cost for the timing belt nad water pump to be replaced?
spluvs2install
Aug 26, 2006 07:40 PM
unhappy_idle
May 22, 2006 10:16 AM
lv6l
Oct 14, 2005 11:52 AM
wonny
Dec 7, 2002 05:45 AM
JDM DC2
Aug 29, 2002 11:39 PM
