ITR flywheel question
Old Jun 16, 2003 | 03:11 PM
scrap1ngsr's Avatar
Default ITR flywheel question
I am about to get my clutch changed and I was thinking about just geting my gsr flywheel resurfaced but i am getting a deal for a type R flywheel with 32k miles on it for 75 bucks..Is a type R flywheel noticebly different then a gsr flyhwheel and is it worth it or not?I would get a aftermarket flywheel but dont have funds.. thanks
Old Jun 16, 2003 | 04:05 PM
scrap1ngsr's Avatar
Default Re: ITR flywheel question (CivicSiR94)
rttt
Old Jun 16, 2003 | 04:21 PM
JChcmax's Avatar
For $75 ,it's definitely worth it. You can tell right away that it
revs faster. You may want to have it re-surfaced
to have a problem free experience, especially with a new clutch.
Old Jun 16, 2003 | 04:22 PM
VTECPWR's Avatar
I would put the money towards lightening and balancing your factory flywheel to 12lbs, if you have a reputable shop in town. I did this and my only complaint is that it is not light enough. I doubt you will feel the 3 lbs between the GSR and the TypeR flywheels.
Old Jun 16, 2003 | 04:27 PM
Asahi's Avatar
Default Re: ITR flywheel question (VTECPWR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECPWR &raquo;</TD></TR><TR><TD CLASS="quote">I would put the money towards lightening and balancing your factory flywheel to 12lbs, if you have a reputable shop in town. I did this and my only complaint is that it is not light enough. I doubt you will feel the 3 lbs between the GSR and the TypeR flywheels.</TD></TR></TABLE>
Not a bad suggestion but that being said 12 lbs is about as light as I would consider safe on a stock GSR flywheel.
Old Jun 16, 2003 | 07:12 PM
scrap1ngsr's Avatar
Default Re: ITR flywheel question (Asahi)
so i should i keep mine and get it resurfaced?
Old Jun 17, 2003 | 06:59 AM
Xsi's Avatar
Xsi
If you keep your one get it resurfaced and lightened, mines down to 6.5 KG's and i haven't had any problems.
if you get the ITR, may as well get it resurfaced since it's on 32K miles
Old Jun 17, 2003 | 08:19 AM
arw321's Avatar
Default Re: (Xsi)
Sorry to hijack your thread, but along the same topic, how light can I safely have my ITR flywheel lightened to?
12 lbs? 10 lbs even?
Thanks,
Adam
Old Jun 18, 2003 | 11:49 AM
scrap1ngsr's Avatar
Default Re: (arw321)
Also this guy is selling me a itr clutch and flywheel for 200 shipped with about 22k miles on it..worth it or not?
Old Jun 18, 2003 | 12:34 PM
scrap1ngsr's Avatar
Default Re: (CivicSiR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiR94 &raquo;</TD></TR><TR><TD CLASS="quote">Also this guy is selling me a itr clutch and flywheel for 200 shipped with about 22k miles on it..worth it or not?</TD></TR></TABLE>
Old Jun 18, 2003 | 03:01 PM
drumking15's Avatar
to correct you on a matter of weight as i recall the itr flywheel is 14lbs ....gsr is 18lbs making it a 4lbs difference....itr work great if you plan on boosting, to light a flywheel will actaully hurt you by letting the revs fall out of range to keep the turbo spool...as a general rule of thumb 12-14lbs is a good flyheel wieght for turbod cars, for n/a usually lighter it is the better just got way to light and youll runinto drivability issues
Old Jun 18, 2003 | 05:23 PM
Asahi's Avatar
Default Re: (drumking15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">to correct you on a matter of weight as i recall the itr flywheel is 14lbs ....gsr is 18lbs making it a 4lbs difference....itr work great if you plan on boosting, to light a flywheel will actaully hurt you by letting the revs fall out of range to keep the turbo spool...as a general rule of thumb 12-14lbs is a good flyheel wieght for turbod cars, for n/a usually lighter it is the better just got way to light and youll runinto drivability issues</TD></TR></TABLE>
Sorry but I have to further correct you. THe GSR is 17 lbs and the Type-R is indeed 15 lbs. Both give a few ounces. I have weighed multiple flywheels of each on a UPS scale and neither came up as heavy or as light as you stated.
Old Jun 19, 2003 | 01:57 PM
drumking15's Avatar
my b....coo i knew i was close but always good to have the correct info now, i just go by what others have stated what they weighed...
hypa
May 2, 2013 09:56 AM
brianmcivics
12
Nov 23, 2007 02:17 PM
Rob1242
Mar 6, 2006 03:07 PM
.one lane
Dec 12, 2005 09:22 AM
Obee1.8
Jul 2, 2003 05:17 PM
