Installing Sparco Grip Pedals, need help with accelerator pedal!
Old Jun 16, 2003 | 01:57 PM
Racer X's Avatar
Default Installing Sparco Grip Pedals, need help with accelerator pedal!
Okay, I have to drill holes to install the bolt and nut to hold the pedals to the original pedals. Unfortunately, the accelerator is not flat on the back side. Is the accelerator pedal all one piece or can I somehow take it apart so I can drill holes and attach the pedal? Thanks, it seems there's always something in the way!
Old Jun 16, 2003 | 04:49 PM
Jeff R's Avatar
New User
Default Re: Installing Sparco Grip Pedals, need help with accelerator pedal! (Racer X)
i installed the omp pedal covers, and the accelerator was definitely a pain in the a$$. the problem is the metal extensions on the back of the pedal that keep you from pushing it down too far (can't think of a better way to explain it, but if you have been trying to install the pedal cover, you know what i am talking about). i ended up bending them out of the way with pliers, drilling right through the middle of the pedal, and then bending them back into place once i put the bolt in. i also heard someone say they cut the bottom parts off with a dremel, which sounds like a good idea, but i was too lazy to try it.
hth,
jeff
Old Jun 16, 2003 | 05:06 PM
CircuitFG's Avatar
for REALZ!!! i have the same pedals and i only have the brake and clutch in at the moment. . i was thinking maybe if i got some longer bolts. .i dunno. . if you figure out how, let me know. .
Old Jun 16, 2003 | 09:41 PM
Racer X's Avatar
Default Re: Installing Sparco Grip Pedals, need help with accelerator pedal! (CircuitDA9)
Update on my "installation": I'm having a hard time. I haven't even begun to drill on the accelerator pedal. I can't get a hole started on the clutch pedal! I got one but the second hole towards the top is a pain because the pedal itself slightly curves so I can't get a good hole started without the drill slipping. Anyways, I gave up cuz I was tired, frustrated and sweaty. I'm sure I'll get it later. Anyways, if I figure out how to get the accelerator pedal installed I'll post it.
Old Jun 17, 2003 | 08:42 AM
BlackAckeR's Avatar
Are you using a punch to start your holes? Then use the smallest steel drill bit you have to get a starter hole through... That's what I did, but it was still a pain in the @ss!
Good luck!
Old Jun 17, 2003 | 08:52 AM
hondaswitch2's Avatar
go to honda or acura and they will pop that back piece off for you thats what i had to do then the pedal will fit fine
SPORT INJECTION
12
Apr 19, 2004 05:11 AM
Teh_Oven
13
Mar 27, 2004 08:21 AM
integra6650
Feb 24, 2003 06:10 PM
Andrew 825SM
Dec 29, 2002 09:16 PM
BlackAckeR
Feb 13, 2002 09:16 AM
