1st gen. hdm b16 head gasket? doing maintenance
sup guy, im doing some maintenance on my car this week. i got spark plugs, ordered a set of blue ngk wires, going to pick up cap and rotor for the distr. later on.
im planning to change the mtf in the tranny. ill pick up a new valve cover gasket. by the way, what else should i get to accompany the valve cover gasket, i kknow wthere are little gaskets that come with some kits, i dunno what they are called
i was wondering about a head gasket, is that easy to do, and is there anything else i should change if i plan to change the headgasket.
most importantly, which head gasket do i get? im thinking the 94 del sol dohc vtec ot 99 si should be correct?
could someone confirm, thanks alot
I have a brand new DOHC VTEC headgasket for sale for cheap if you want it. I have never used it.
IM me if you want it. I will make sure that you save money on it compared to what the dealership will ask for it.
BTW...all DOHC VTEC headgaskets are the same.
DelSol-B-18
Apr 8, 2005 06:46 AM
